Does mipmapping in TinyGL work?
  • MDW
    MDW
    Posts: 415 from 2003/7/26
    Does mipmapping work in current version of TinyGL? I am not sure...
    After using:
    gluBuild2DMipmaps(GL_TEXTURE_2D, depth, width, height, GL_RGB, GL_UNSIGNED_BYTE, data);
    when I check:
    glGetError();
    result is 0 (GL_NO_ERROR).
    However I don't see mipmaps on small/far objects which should use smaller textures.
    I use in MorphOS gluBuild2DMipmaps() because glTexParameteri(GL_TEXTURE_2D, GL_GENERATE_MIPMAP, GL_TRUE) doesn't work in TinyGL (includes in the latest SDK don't contain GL_GENERATE_MIPMAP);
    This is problematic for me because this is reason why MorphOS version of application works slower than version for other platforms. MOS version is the most important for me. :)
    [ Edited by MDW 01.07.2020 - 19:16 ]
  • »01.07.20 - 16:58
    zukow
    Posts: 636 from 2005/2/9
    Could you provide some code example for quickchecking?
  • »01.07.20 - 20:05
  • MDW
    MDW
    I am sure that a code example could solve the problem because... I am stupid. :) I have already found reason of the problem. It was my stupid mistake. This is part of huge code which can be compiled on various platforms. There are too many #ifdef. After small refactor in this year I didn't notice below these #ifdefs one line which disables mipmaps in case of MorphOS. I can't believe, I checked this part 2-3 hours... :)
    So mipmapping works and application now is faster. :) I have to update applications which have been already released.
    The topic should be removed... shame...
    Thanks and greetz! :)
    [ Edited by MDW 01.07.2020 - 22:15 ]
  • »01.07.20 - 21:13
    zukow
    screenshot? :)
  • »01.07.20 - 21:18
  • MDW
    MDW
    zukow wrote:
    screenshot? :)
    Screenshot of code? No! :)
  • »08.07.20 - 09:29
