X5000 CDROM Japaleno
    Posts: 20 from 2018/4/2
    I will continue with my issues, it has worked for the sound so i hope it will be the same for the CDRO :)
    I cannot burn CD/DVD when the CD player is connected to the motherboard because the size avalaible on the device is not recognized. I have always 0.00 mb available ..cannot burn.
    On the other hand if i cannot the player on my additionnal PCI sata card it works.
    So it is a work around, but each time i need to boot on the cdrom i need to change the sata connexion and for me it is not really good for the hardware
    Any idea ?
  • »08.06.20 - 10:29
    Posts: 3214 from 2003/3/5
    We're aware of this issue. Unfortunately there's no workaround for now.
  • »08.06.20 - 14:09
    ok
    i will continue to switch between the two controllers.
  • »08.06.20 - 14:44
