Sam460ex - Ethernet (10 Mbit) link only
    Posts: 78 from 2020/5/1
    So, the Sam460ex and my router/gateway support 1000 Mbit. But I only get a 10 Mbit link with MorphOS. Is this a known limitation of the driver?
    Edit: changed cable and router/gateway, still 10 Mbit link speed only.
    [ Edited by duga 06.05.2020 - 21:46 ]
  • »06.05.20 - 17:19
    Actually, I haven't yet checked speed/duplex at the other end. It might be that it's only _reported_ as 10 Mbit.
    Is it possible to change speed/duplex and autoneg on/off?
  • »07.05.20 - 20:35
    I can confirm it's linked in 1000 Mbit, but reported as 10 Mbit.
    I might try to read the actual value (in bits) reported by the eth chipset, via SANA.
  • »08.05.20 - 13:16
    Posts: 2971 from 2003/3/5
    Confirmed to be a reporting issue.
  • »08.05.20 - 13:34
    Reporting, or reported? I'm reading this as something that has been reported before and is a known bug. Correct me if I'm wrong.
  • »08.05.20 - 13:41
    Piru
    Posts: 576 from 2003/2/24
    The driver merely reports the speed wrong.
  • »08.05.20 - 14:15
    Ah, now I get it. Thanks.
  • »08.05.20 - 14:17
    How can one help fixing/updating the Sam460 eth driver so that it can report 100 and 1000 Mbit link?
  • »07.10.20 - 20:32
    Posts: 537 from 2003/4/11
    Well, it's on our bugtracker, it will possibly be targeted for 3.15, it didn't make it into 3.14, unfortunately.
  • »09.10.20 - 09:31
    Is it possible to "sign up" as beta tester/developer for a single driver? With access to only the source code needed for the driver, nothing else.
  • »09.10.20 - 11:34
    Happy to see the link speed shown as 1000 Mbps in MOS 3.15.
  • »31.12.20 - 17:34
