Posts: 588 from 2010/2/10
Piru a écrit :
To be able to fix such issues the report should include instructions on how to reproduce it. Else there is little that can be done.
ok, sorry....
Configuration : Last SDK (April)
You have all sources codes on github, just make -f makefile.mos
Report "Logtool" : example when i launch OpenBOR but all SDL2 programs are same error (Hode ScummVM, zgloom etc.....)
Need to reboot after crashlog, Morphos become instable...
First offset : LIBS:sdl2.library [Hunk 1 Offset 0x00000f90] correspond to function "AMIGA_Startup"
https://github.com/BSzili/SDL/blob/mos-sdl2/src/core/morphos/SDL_startup.c
[20200423 15:14:45] >>> Exception 3 <Illegal Data Access at 13fffa71 DSISR 42000000, Store to a not existing Page>
Quark Thread TID 0000000010020010 Name ABox
SRR0 0x4e800020 SRR1 0x0200f030
LR 0x19c1668c CTR 0x4e800020
CR 0x42000243 XER 0x20000400
GPR[00] 19c1665c 19c14cf0 165a5800 1654e608 140000a8 00000000 165abdc8 14000048
GPR[08] 165a5a78 4e800020 00000000 14001948 24000248 18e047c0 00000000 00000000
GPR[16] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 fd7932c8
GPR[24] 18df98ec 18dfc70c 196f70a0 18dfc7c0 14001948 165abdc8 165af3c4 165af210
FPSCR 82020000
FPR[00] 0000000000000000 0000000000000000 4082600000000000 4050000000000000
FPR[04] 4084600000000000 0000000000000000 0000000000000000 3ff0000000000000
FPR[08] 3ff0000000000000 4060000000000000 41e0000000000000 4330000000000000
FPR[12] 412ce2127caaaaab 403b8790db69198d 0000000000000000 0000000000000000
FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
VSAVE 00000000 VSCR 00010000
VPR[00] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[02] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[04] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[06] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[12] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[14] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[16] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[18] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[20] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[22] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[24] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[26] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[28] 00000000000000000000000000000000 00000000000000000000000000000000
VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
IABR 00000000
DABR 00000000
MMCR0 00000000
MMCR1 00000000
MMCR2 00000000
PMC1 00000000 PMC2 00000000 PMC3 00000000 PMC4 00000000
SIA 00000000
SDA 00000000
>>> Quark Thread Stack History
StackFrame[ 0].LR[0x19c16008] -> LIBS:sdl2.library [Hunk 1 Offset 0x00000f90]
StackFrame[ 1].LR[0x1010afcc] -> exec_of_604e.elf [Hunk 0 Offset 0x0000afcc Function OpenLibrary]
StackFrame[ 2].LR[0x102cc058] -> ramlib.elf [Hunk 0 Offset 0x00000998]
StackFrame[ 3].LR[0x102cc6d0] -> ramlib.elf [Hunk 0 Offset 0x00001010]
StackFrame[ 4].LR[0x1961f524] -> OpenBOR [Hunk 1 Offset 0x0010c2a4]
StackFrame[ 5].LR[0x19513774] -> OpenBOR [Hunk 1 Offset 0x000004f4]
StackFrame[ 6].LR[0x19513614] -> OpenBOR [Hunk 1 Offset 0x00000394]
StackFrame[ 7].LR[0x1010f98c] -> exec_of_604e.elf [Hunk 0 Offset 0x0000f98c Function NewPPCStackSwap]
>>> ABox State
ExecBase: SysBase 0x14001948
SysFlags 0x0000 AttnResched 0x0000 IDNestCnt -1 TDNestCnt 0
ThisTask 0x165abdc8 TaskReady 0x14001ae2 TaskWait 0x140243b0
ResModules 0x140040e8
TaskTrapCode 0x10120de4 TaskExceptCode 0x10120dec TaskExitCode 0x10120e48
TaskSigAlloc 0xffff TaskTrapAlloc 0x8000
IdleCount 15258 DispCount 246356
Quantum 4 Elapsed 3
VBlankFrequency 50 PowerSupplyFrequency 50 EClockFrequency 709379
MainTID 0x10020010 SchedulerTID 0x10020012 SchedulerSig 0x80000000
OldSRR0 0x0
ConfigServerTID 0x10000013
LastIntObject 0x1411c4f4
LastIntObject 0x1411c4f4 <Not Valid ptr>
Code 0x1046e3c0 Data 0x14094088
Int0: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int1: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int2: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int3: iv_Code 0x101262b8 iv_Data 0x14003b40 iv_Node 0x00000000
Int4: iv_Code 0x101262b8 iv_Data 0x14003b60 iv_Node 0x00000000
Int5: iv_Code 0x101262b8 iv_Data 0x14003b50 iv_Node 0x00000000
Interrupt 0x1402e476 <graphics.library>
Code 0x1018dbe8 Data 0x1402e42c
Interrupt 0x14d90708 <ixemul timer interrupt>
Code 0x14d8d7f0 Data 0x00000000
Int6: iv_Code 0x1018dbf0 iv_Data 0x1402e42c iv_Node 0x1402e4a2
Int7: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int8: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int9: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int10: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int11: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int12: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int13: iv_Code 0x101262b8 iv_Data 0x14003b70 iv_Node 0x00000000
Int14: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
Int15: iv_Code 0x101262b8 iv_Data 0x14003b80 iv_Node 0x00000000
>>> Running Task
Task 0x165abdc8 Name 0x165aceac <OpenBOR> Type 13 Pri 0
Flags 0x8 State 2 IDNestCnt -1 TDNestCnt -1
SigAlloc 0x0000ffff SigWait 0x00000010 SigRecvd 0x00000100 SigExcept 0x00000000
ExceptCode 0x10120dec ExceptData 0x00000000 TrapCode 0x10120de4 TrapData 0x00000000
Switch 0x00000000 Launch 0x00000000 UserData 0x00000000
SPLower 0x165abeac SPUpper 0x165aceac SPReg 0x165ace48
MemList 0x16984de8 Entries 0x1
Address 0x16531ae0 Size 0x14
MemList 0x1471b5c0 Entries 0x1
Address 0x165abdc8 Size 0x10ec
ETask 0x152799b4
MemPool 0x144a47c8 PPCLibData 0x00000000
PPCSPLower 0x19a2cbdc PPCSPUpper 0x19c15050
PPCTrapMsgPort 0x00000000 PPCTrapMessage 0x14721a6c
PPCRegFrame 0x165a5410
Private[] 0x00000000 0x00000000 0x00000000 0x00000000
EmulHandle 0x00000000
EmulHandle 0x165a5800 Type 0x00000004 Flags 0x00000001
SuperHandle 0x10001000 Type 0x00000000 WaitMask 0x00000000 SyncMask 0x00000000
USP 0x00000000 SSP 0x140037a0 VBR 0x1400e238
SFC 0x00000000 DFC 0x00000000 CACR 0xa0808000 TC 0x00000000
ITT0 0x00000000 ITT1 0x00000000 DTT0 0x00000000 DTT1 0x00000000
URP 0x00000000 SRP 0x00000000 BUSCR 0x00000000 PCR 0x04310501
>>> Task Registers Frame
FPSCR 82020000
VPR[00] 1133af6a000000080000000178300000 11330000000000001a1a1a1a1b1b1b1b
VPR[02] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000d97000044e381e1e1e1e00000007
VPR[04] 1010f98c11393c58000000000000f98c 1133aefc11397c411a1a1a1a1b1b1b1b
VPR[06] 1000d9301d1d1d1d14001b5c1133ae58 1000d93000044e380000000000000000
VPR[08] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000d97011006c9c11393c5800000000
VPR[10] 1010f98c1000d9781000d97c1000d980 1000d9601000d9780000000000000030
VPR[12] 1000d9700001182c1000d8d800000000 1000d98000044f580000000000000000
VPR[14] 1000d9c0000457042002488413131313 1000d9a0151515151000d9f00000000a
VPR[16] 1000d9b00001182c1e1e1e1e0000000a 1000d9c00001182c1000d9f000000000
VPR[18] 1000d9d000044f58000000001000dad0 1000da5000045fe80000000178300000
VPR[20] 00000000000000000000000000000000 30003000336238300000000000000000
VPR[22] 00000000000000000000000000000000 1133ae1c000000000000000000000000
VPR[24] 113390c8000000001a1a1a1a1b1b1b1b 1c1c1c1c1d1d1d1d1a1a1a1a1b1b1b1b
VPR[26] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000daf000044e380000000000000000
VPR[28] 0000000100b520080000000a000015e0 11339aa800b538880000000000000000
>>> Task Stack History
LR[0x19c1668c] -> LIBS:sdl2.library [Hunk 1 Offset 0x00001614]
Stack: 0x19c14cf0
0x19c14cd0[-0x20] 18df98ec 18dfc70c 196f70a0 18dfc7c0
0x19c14ce0[-0x10] 14001948 165abdc8 165af3c4 165af210
0x19c14cf0[0x000] 19c14d30 19c1665c 800003f4 18e0c07c
0x19c14d00[0x010] 80000001 18e047c0 00000000 165acea4
0x19c1665c -> LIBS:sdl2.library [Hunk 1 Offset 0x000015e4]
0x18e0c07c -> LIBS:sdl2.library [Hunk 3 Offset 0x0000015c]
>>> Full PPC mode: Last saved 68k context
PC 87654321 SR 0000
Dn[0] 00000070 00000000 0000000b 19c148e0 101097ec 00000000 00000000 00000048
An[0] 165a5a78 18dfc7c0 1553f068 19c148f0 1010a140 102c39d8 14001948 165acea8
Stack: 0x165acea8
0x165ace88[-0x20] 00000000 00000000 00000000 00000000
0x165ace98[-0x10] 00000000 00000000 00000000 1133e218
0x165acea8[0x000] 00001000 4f70656e 424f5200 0003a174
0x165aceb8[0x010] 165abdc0 00002028 1466c8b0 15252388
0x165acec8[0x020] 0d05165a eee40804 ffffc000 ffffc000
0x165aced8[0x030] 00000000 01000000 0000165a ba8c0000
0x165acee8[0x040] 00001012 0dec0000 00001012 0de4165a
0x165acef8[0x050] ee80165a cfa4165a eee40000 00000000
0x165acf08[0x060] 000014be 29e80000 0000168d 4e900000
0x165acf18[0x070] 00000000 00000000 00000000 04000000
0x10120dec -> exec_of_604e.elf [Hunk 0 Offset 0x00020dec]
0x10120de4 -> exec_of_604e.elf [Hunk 0 Offset 0x00020de4]
>>> Last saved PPCThread State
SRR0 0x1011ff18 SRR1 0x0200f030
LR 0x1010eeb4 CTR 0x11007600
CR 0x88000884 XER 0x00000400
GPR[00] 00000000 19c14b10 165a5800 140012ec 00000000 00000004 11008d3c 11008d48
GPR[08] 11010000 11008b94 11007600 11008930 14936348 00000000 00000000 00000000
GPR[16] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000004
GPR[24] ffffffff 14001af0 14001aec 00000001 ffffffff 88000844 14001948 165abdc8
FPSCR 82020000
SRR0[0x1011ff18] -> exec_of_604e.elf [Hunk 0 Offset 0x0001ff18]
LR[0x1010eeb4] -> exec_of_604e.elf [Hunk 0 Offset 0x0000eeb4 Function Wait]
CTR[0x11007600] -> Emulation [Hunk 0 Offset 0x00007600]
StackFrame[ 0].LR[0x1010e880] -> exec_of_604e.elf [Hunk 0 Offset 0x0000e880 Function WaitPort]
StackFrame[ 1].LR[0x102cc058] -> ramlib.elf [Hunk 0 Offset 0x00000998]
StackFrame[ 2].LR[0x102cc6d0] -> ramlib.elf [Hunk 0 Offset 0x00001010]
StackFrame[ 3].LR[0x19c16008] -> LIBS:sdl2.library [Hunk 1 Offset 0x00000f90]
StackFrame[ 4].LR[0x1010afcc] -> exec_of_604e.elf [Hunk 0 Offset 0x0000afcc Function OpenLibrary]
StackFrame[ 5].LR[0x102cc058] -> ramlib.elf [Hunk 0 Offset 0x00000998]
StackFrame[ 6].LR[0x102cc6d0] -> ramlib.elf [Hunk 0 Offset 0x00001010]
StackFrame[ 7].LR[0x1961f524] -> OpenBOR [Hunk 1 Offset 0x0010c2a4]
StackFrame[ 8].LR[0x19513774] -> OpenBOR [Hunk 1 Offset 0x000004f4]
StackFrame[ 9].LR[0x19513614] -> OpenBOR [Hunk 1 Offset 0x00000394]
StackFrame[10].LR[0x1010f98c] -> exec_of_604e.elf [Hunk 0 Offset 0x0000f98c Function NewPPCStackSwap]
SegList 0x0594c6b8 GlobVec 0x1402356c
StackBase 0x0596afab StackSize 0x00001000
TaskNum 0x00000000 Result2 0x00000000
CurrentDir 0x0604f4f0 CIS 0x00000000
COS 0x00000000 CES 0x00000000
ConsoleTask 0x17fe9c98 FileSystemTask 0x140cbc74
CLI 0x00000000 ReturnAddr 0x165acea8
PktWait 0x00000000 WindowPtr 0x00000000
HomeDir 0x059507be Flags 0x00000000
ExitCode 0x00000000 ExitData 0x00000000
Arguments 0x00000000 ShellPrivate 0x00000000
[20200423 15:14:45] >>> End of Exception State Dump
[20200423 15:14:45] >>> Exception 4 <Illegal Inst Access at 017c1118>
SRR0 0x017c1118 SRR1 0x4200f030
CR 0x48000243 XER 0x20000400
FPSCR 86005000
FPR[00] 7ff0000000000000 0000000000000000 4082600000000000 4050000000000000
IABR 00000000
DABR 00000000
MMCR0 00000000
MMCR1 00000000
MMCR2 00000000
SIA 00000000
SDA 00000000
>>> ABox State
SysFlags 0x8000 AttnResched 0x0000 IDNestCnt -1 TDNestCnt 0
ThisTask 0x165abdc8 TaskReady 0x16976d80 TaskWait 0x140243b0
Quantum 4 Elapsed 2
OldSRR0 0x0
>>> Running Task
ETask 0x152799b4
FPSCR 86005000
VPR[14] 1000d9c0000457042004288413131313 1000d9a0151515151000d9f00000000a
VPR[28] 0000000100b520080000000a0000531d 11339aa800b575c50000000000000000
>>> Task Stack History
Stack: 0x19c14cf0
PC 87654321 SR 0000
Stack: 0x165acea8
FPSCR 82020000
IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
My MOS ports
