How to upgrade morphos install in triple boot?
  • esc
    esc
    Posts: 144 from 2013/5/28
    Hey guys,
    I have a triple boot setup - OSX, MorphOS, Linux (gentoo).
    Obviously my partitioning scheme is a mess :)
    I'd like to upgrade MorphOS, the easiest way really is to just reinstall from scratch. However I'd like to make sure I don't overwrite any other partitions or screw up any boot stuff.
    Right now, the gentoo bootloader (yaboot) loads during boot and points at the other OSes. If I install a new MorphOS over existing, will that screw up anything in yaboot?
    Thanks!
  • »23.04.20 - 20:56
    AKiLL
    Posts: 77 from 2006/3/6
    You'll probably find what you are looking for in the following thread.
  • »23.04.20 - 22:14
  • esc
    esc
    Thanks! In any case, if I screw something up, it looks recoverable. I remember that thread actually, it's what helped me figure this out in the first place lol.
  • »24.04.20 - 06:25
