TinyGL : GL_BGRA format
    beworld
    Posts: 664 from 2010/2/10
    Hi all !
    Is it possible to support the GL_BGRA format for the glTexImage2D input and glReadPixels output ?
    We need this possibility to continue our tests with SDL 2 RENDERER.
    SDL2's State :
    https://github.com/BSzili/SDL/commits/mos-sdl2
    https://github.com/BSzili/SDL/blob/mos-sdl2/TODO.MORPHOS
    Thanks you
    BeWorld
    [ Edité par beworld 19.03.2020 - 14:38 ]
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »19.03.20 - 11:38
    beworld wrote:
    Hi all !
    SDL2's State :
    Thanks you
    BeWorld
    Although a few of the MorphOS Dev. Team members post forum messages on this site, I don't think that asking for specific graphic support here is the best place to get a quick response. Don't you think that trying to post this question to the official MorphOS website, or to several of the email addresses for certain MorphOS Dev. Team members shown on the official site, would be a better place to send your question?
    Unless I am not understanding your question correctly (which wouldn't be the first or last time for me), what you are asking can only be added to the core of MorphOS by the team members working on the video card drivers. Bigfoot would probably be the best team member to send this request to, IMHO.
  • »19.03.20 - 16:36
    Posts: 12405 from 2003/5/22
    > post this question to the official MorphOS Website
    How would this be done?
  • »19.03.20 - 22:41
    Posts: 545 from 2003/4/11
    I think that GL_BGRA is actually supported for texture input but reading pixels back via GL_BGRA won't work and needs some workaround that does conversion from GL_RGBA to GL_BGRA.
    It should be possible to fix that for a future release.
  • »20.03.20 - 12:02
    BSzili
    Posts: 561 from 2012/6/8
    Thank you, that would be great! Here's an example of what we got with TGLDEBUG:
    TGL:[ 477]/GLGenTextures() : Allocating texture:1
    TGL:[1140]/GLTexImage2D() : (1)format:0x80e1, tgldInternalFormat:0x1908 (GL_RGBA). width:1024, height:512
    TGL:[2321]/GLTexSubImage2D() : update:(1)format:0x80e1 (GL_BGRA), internalformat:0x1908(GL_RGBA) (640x480 pixels) source:644460568
    TGL:[1520]/gl_convertGL_to_GL() : Unsupported image format:format:0x80e1(GL_BGRA) . dstFormat:1908(GL_RGBA)
    [ Edited by BSzili 20.03.2020 - 17:27 ]
  • »20.03.20 - 14:05
    beworld
    Hi !
    Any update ?
    SDL2 now work fine, i port a lot of games with it.
    It would be formable if we could activate SDL_VIDEO_RENDER_OGL.
    Thanks
    My MOS ports
  • »23.04.20 - 09:18
