freetype.library SDK
    BSzili
    Posts: 561 from 2012/6/8
    I noticed that the headers for freetype.library are missing from the current SDK. Was this already the case, or are they available in an older version of the SDK?
  • »04.04.20 - 16:10
    Posts: 3210 from 2003/3/5
    As far as I can tell, this was never part of the SDK - or perhaps only by accident.
  • »04.04.20 - 21:18
    BSzili
    I see, so it's not meant to be used by third party programs? I'm asking because PowerSDL's sdl_ttf.library used it.
  • »05.04.20 - 04:00
    I'll have to get back to you on this :)
  • »06.04.20 - 00:53
    BSzili
    Thanks. If it's not for public consumption, I'll statically link freetype. I just thought I'd do the same as PowerSDL to reduce the library size, since it looked API compatible based on SDL_ttf's sources.
  • »06.04.20 - 04:31
