[SOLD]: 17" PowerBook G4 1,67 GHz (A1107)
    Posts: 1003 from 2004/2/8
    I have a G4 PowerBook for sale. Specs:
    - PowerPC 7447a (G4) CPU at 1,67 GHz
    - 2 GB PC3200 DDR RAM (maximum for this model)
    - 17 inch 1920x1200 display (I've swapped the original 1440x900 screen with WUXGA one)
    - 120 GB mSATA SSD hard drive
    - Radeon Mobility 9700 with 128 MB VRAM
    - 8X "SuperDrive" optical drive
    - built-in Bluetooth and Airport
    - genuine Apple 65W power supply (with european plug)
    - US/ENG keyboard layout
    - MorphOS 3.13 (not registered) installed
    Downsides:
    - the battery is pretty much dead. It holds the charge only for a few minutes
    - the display has a slight brighter discoloration along the top border (tried to show it on the photos, not sure if it's visible as it can be seen only at certain angles).
    Some photos available here.
    EDIT: Sold, thanks.
    [ Edited by koszer 25.02.2020 - 16:05 ]
  • »18.02.20 - 21:45
    I've decided to drop the price to 125 EUR.
  • »20.02.20 - 07:50
    I can further reduce the price by swapping the updated components with standard ones.
    Base price: 125 EUR.
    Without the WUXGA 1920x1200 display (original 1440x900 instead): -50 EUR.
    Without the 120 GB SSD mSATA drive (original 2,5" 100 GB one instead): -25 EUR.
    So we can go down to 50 EUR for the computer if you wish.
  • »22.02.20 - 12:18
    dkaram
    Posts: 9 from 2010/1/26
    Interested in the item. P.m for details.
  • »22.02.20 - 17:21
    soviet
    Posts: 101 from 2008/7/2
    Downsides:
    EDIT: Sold, thanks.
    Hi may i ask you the display you used for replacement is from a macbook pro 17 ?, i don't remember that the g4 have a factor 1920 display
  • »09.03.20 - 16:31
    From my experience so far:
    - MacBook Pro 17 inch 1920x1200 (matte) WUXGA display works OK
    - LP171WU3(TL)(B1) (matte) WUXGA display works OK (may need a different re-route of inverter cable as it's located in slightly different place than the MacBook one
    - LP171WU1(TL)(A7) (glossy) WUXGA display didn't work for me (not quite sure if it was faulty display or some other factor)
  • »09.03.20 - 18:14
