Heretic II
    xyphoid
    Posts: 870 from 2008/7/11
    Does Heretic II work on efika? Anyone played it successfully?
  • »10.01.09 - 16:11
    XzIt
    Posts: 250 from 2005/1/19
    not sure about that xyphoid, own a pegasos 2..
    but need some help here, trying to run heretic 2 and have some questions.
    lets start at beginning, when installing the game, should i choose yes to config warp3d ?
    if yes what should i choose on these setrtings? i havent configed the file.
    when trying to icon, exe file. snoopdos tells me it needs wizard.library? does it need it?
    the window comes and i can choose my settings.
    in the "Game" section i choose my device, unit and choose use mouse. i leave addon and options blank.
    in the "Display" section i choose use Triple-Buffering and use RTGMaster everything else is grey.
    in the "Paths" section i choose nothing, i quess this is "standard setup" =)
    when i choose "start game" the screen goes to new screen thats grey and nothing happens..
    any clues whats the problem?
    X
  • »20.10.09 - 16:37
    Posts: 1335 from 2004/2/8
    Yup, Heretic II works just fine on my Efika.
    @XzIt - Try copying wizard.library to libs: - I remember I did. Not quite sure if that did the trick though.
  • »20.10.09 - 18:43
    Where can I find more info about installing Heretic II on my Efika and MacMini?
    Also, what are the chances of getting Descent 2 ported to MorphOS now that it has been ported to AmigaOS4.x?
  • »21.10.09 - 00:40
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Descent 2 was ported about 4 years ago by itix.
  • »21.10.09 - 01:19
    Posts: 12408 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=3936&forum=9
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=3011&forum=10&start=20#37111
    I think it's there for a while already.
    "Date: 27 May 08"
    http://os4depot.net/index.php?function=showfile&file=game/action/d2x.lha
    But MorphOS port has been in existence for some years longer.
  • »21.10.09 - 02:25
    stephen_robinson
    Posts: 746 from 2007/4/22
    Sorry about the thread Necrophilia, but what do you need to play Heretic 2 on MorphOS, the amiga release?
    eg.
    http://amigakit.leamancomputing.com/catalog/product_info.php?products_id=370
  • »19.06.11 - 12:33
    boot_wb
    Posts: 874 from 2007/4/9
    stephen_robinson,
    I assume you mean necromancy, but hey, each to their own! ;-)
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »19.06.11 - 12:39
    stephen_robinson
    I know what I mean... 8-)
  • »19.06.11 - 12:54
    Yes, at least I'm not aware of any open source reimplementation of this game. http://www.osgameclones.com doesn't list one either.
  • »19.06.11 - 13:23
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    amigadave,
    I just installed it on my macmini using the amiga cd installer, completed the game without any running issues :-)
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »19.06.11 - 17:53
    stephen_robinson
    In that case I'll probably get a copy from Amigakit next time I get paid, had it on PC, still got it the PC version someplace, must give it another go..
  • »20.06.11 - 19:47
    Thinking of buying this game, as it seems to run on MorphOS according to a few MorphOS users who have posted to this thread.
    Anyone care to comment on the game? A short review of the game play, how it runs, how the graphics look?
    Are there any extra files or libraries that need to be installed first for this game to run correctly on MorphOS2.7?
    If anyone has this game and no longer wants it as they have played it a few times already and it no longer interests them, I would not be opposed to buying it used from anyone that no longer wants their complete package of this game.
    I am also open to suggestions for other games to run on MorphOS2.7. Preferably without needing E-UAE to run. I am not much of a gamer at all, but thought I would check out this game and any others that run on MorphOS and are recommended by other members here on MZ.org.
    I don't currently own a USB joystick or joypad, but I think I do have a USB to 9pin adapter, so I can use any of my Amiga joysticks in a USB port, but I don't remember how well the response time is when using this adapter, or if it is difficult to assign games to use this USB to 9pin adapter and Amiga joystick, while running MorphOS2.7.
    [ Edited by amigadave 14.04.2012 - 15:57 ]
  • »14.04.12 - 23:54
    BSzili
    Posts: 561 from 2012/6/8
    Time to resurrect the Heretic II thread.. again  :-) I installed the game on my Mac Mini a few days ago. It runs well, but there are a few minor issues.
    I get no texture filtering, except for the skybox, the console background and some sprites.
    There's no music. Is there any way to get the CD audio working on MorphOS?  :-?
  • »23.06.12 - 15:22
  • TGR
    TGR
    Copy the cd to one of your partitions and make an assign to it in your user-startup
    assign Heretic_IIB: DH2:Heretic_IIB
    [ Edited by TGR 23.06.2012 - 19:52 ]
  • »23.06.12 - 17:46
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Using pc files on amiga version didn't work?. I'm wondering, because if you have it on pc, it's a pity you have to bought it again. Doesn't use the same estructure on levels like quake, when you put your own levels from the pc version, then run the Amiga executable?.
  • »23.06.12 - 18:32
    BSzili
    Umm, I think you have misunderstood me a bit. I wasn't talking about playing the game without the CD in the drive.
    I miss the CDDA music playback. The game used cybppc.device to access the CD on classic amigas, for playing the CD audio music. I'm interested if there's any replacement for it on MorphOS.
  • »23.06.12 - 19:00
    The Heretic II Amiga executable isn't free, so you have to buy the Hyperion version including data files anyway.
  • »23.06.12 - 19:15
    Divinity
    Posts: 498 from 2009/9/8
    same question, is there a way to use the CD audio music tracks ?
    (Pegasos 2 with DVD and analogic audio cable connected to the mainboard)
    (using ide.device and ID of the DVD is 3)
    (CD audio music tracks are ok if played with Ambient_SoundPlayer)
  • »09.02.20 - 21:48
    Divinity
    solved: mixer IN CD was mute
    other question: to see video movies, do I need to create a new video mode 320x200x8bit ?
  • »09.02.20 - 22:30
    Divinity
    solved: created a new 320x240x8bit mode
    Is It possible to add a SoundBlaster Live PCI card or SoundBlaster 128 PCI card in PowerMac G5 to use correctly the mixer IN CD-ROM ?
    SoundBlaster Live PCI card is 3.3V while SoundBlaster 128 PCI card is 5V
    (app mixer is 1.8 04.12.2010 by IIkka Lehtoranta)
  • »09.02.20 - 23:17
    > in PowerMac G5 to use correctly the mixer IN CD-ROM ? SoundBlaster Live PCI
    PowerMac G5 PCI(-X) is 3.3V, so 5V-only cards won't fit/work. There has been a thread on the topic of SoundBlaster Live on G5, but no replies so far:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12457&forum=11
  • »10.02.20 - 11:04
    Divinity
    added a SoundBlaster Live PCI in PowerMac G5 and works very well, same as the CDROM audio in AUX IN of the SoundBlaster Live PCI, all fine
    Mixer is OK to control it
    added at the end a RV280 128mb flashed from PC in the PowerMac G5 and Goa reimplementation of the Warp3D.library is OK
    edited all gfx modes from panel, all fine
  • »10.02.20 - 22:47
