compile example of libcurl
    beworld
    Posts: 664 from 2010/2/10
    Hi all
    I want to compile an example (simple) of libcurl : https://curl.haxx.se/libcurl/c/https.html
    I have MOS 3.12/SDK3.14, no external libcurl or openssl.
    I made my makefile :
    CC = gcc
    GCC = g++
    CFLAGS = -O2 -noixemul -I/usr/local/include -Wall
    LDFLAGS = -lcurl -noixemul -L/gg/ssl/lib -lssl -lcrypto -lz -lpthread
    DEFINES =
    OUTPUT = simple
    SOURCES = simple.o
    OBJS = ${SOURCES:*.c=.o}
    ${OUTPUT}:${OBJS}
    ${GCC} -o ${OUTPUT} ${SOURCES} ${LDFLAGS} ${DEFINES}
    clean:
    rm *.o *.o ${OUTPUT}
    and when i make this.. i have a lot of error :
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/5.5.0/../../../../ppc-morphos/bin/ld: /System/Development/gg/bin/../../gg/usr/lib/libcurl.a(libcurl_la-easy.o): in function `sigpipe_ignore.isra.1.part.2':
    easy.c:(.text+0x10c): undefined reference to `sigaction'
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/5.5.0/../../../../ppc-morphos/bin/ld: easy.c:(.text+0x134): undefined reference to `sigaction'
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/5.5.0/../../../../ppc-morphos/bin/ld: /System/Development/gg/bin/../../gg/usr/lib/libcurl.a(libcurl_la-easy.o): in function `curl_easy_perform':
    easy.c:(.text+0x4c4): undefined reference to `sigaction'
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/5.5.0/../../../../ppc-morphos/bin/ld: /System/Development/gg/bin/../../gg/usr/lib/libcurl.a(libcurl_la-easy.o): in function `curl_easy_cleanup':
    easy.c:(.text+0x5cc): undefined reference to `sigaction'
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/5.5.0/../../../../ppc-morphos/bin/ld: /System/Development/gg/bin/../../gg/usr/lib/libcurl.a(libcurl_la-multi.o): in function `sigpipe_ignore.isra.5.part.6':
    etc......
    Finally i want to active "cloud" and "libcurl" on ScummVM.
    Any ideas ? ixemul ? version of gcc ?
    Thanks.
    [ Edité par beworld 02.11.2019 - 17:38 ]
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »02.11.19 - 15:34
    Posts: 3210 from 2003/3/5
    That looks like trying to link ixemul libraries to a non-ixemul binary.
  • »02.11.19 - 15:43
    beworld
    ok thanks, where i find libcurl/openssl etc.. for non-ixemul ?
    My MOS ports
  • »02.11.19 - 16:11
    BSzili
    Posts: 561 from 2012/6/8
    I built them myself (at least CURL) when I needed them, as I couldn't find them built for libnix either :\
  • »02.11.19 - 19:46
