Shell: ESC character not working
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    Echo "*E[3mItalics*E[23m"
    On AmigaOS this would print:
    Italics
    to the console.
    As there are quite some threads on MorphZone discussing esc sequences I suppose, MorphOS does support them too ?
    But wenn I try this on MOS (3.9) , nothing happens and console is stuck, everything I input is written to the console, but besides that nothing happens. ctrl etc doesn't work either.
    Any ideas ? Maybe a configuration problem ?
    btw, what is the placeholder für the Input/Output of current console ? On AmigaOS it was *
    [ Edited by pOS 06.09.2019 - 04:19 ]
  • »06.09.19 - 00:18
    Posts: 2159 from 2003/2/24
    It should work just like on Amiga, and your example does work fine here on MorphOS. So... I guess it's something in your config, but I have no idea what it would be...
  • »06.09.19 - 03:14
    Posts: 1325 from 2010/1/6
    Does also work fine here (MOS 3.11).
  • »06.09.19 - 08:00
