Just bought a Mac mini G4
    Posts: 14 from 2019/5/15
    koszer wrote:
    Madlax72 wrote:
    It’s an A1103 with 1.5GHz G4. I just reread the listing on eBay it doesn’t have any more information regarding the exact version. I guess I will find out on Monday
    If the serial number is visible anywhere on the photos then you can check using it. If there is no serial number (peeled of or not visible on your photos) then I'd suggest being extra careful. Does it have a built-in modem, or just a plug in its place? If the latter, then your chance of 64 MB VRAM grows.
    I just got it. It’s the 64MB version :-)
  • »18.05.19 - 03:53
    NewSense
    Posts: 767 from 2012/11/10
    ENJOY 8-D ... More Fun with MorphOS
    MacMini 1.5GHz,10,2,64MB VRAM,1GB RAM,Airport, Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL+CD-RW,Iomega MiniMax,Belkin 6 port 3 x Firewire/3 x USB2,MorphOS 3.11,Mac OSX 10.4/10.5,A1138+A1139 PwrBk MOS v3.11,Model 5,8/5,9, & PowerMac G5 2.3GHz (DP)
  • »18.05.19 - 18:10
