Posts: 389 from 2003/2/25
One can also use SendRexxCommand() to show a bubble with MagicBeacon
Function p_MOSToast(text$, t)
Local str$
str$ = "BUBBLE \""..text$.."\""
If HaveItem(t, "x") Then str$ = str$.." X "..t.x
If HaveItem(t, "Y") Then str$ = str$.." Y "..t.y
If HaveItem(t, "Font") Then str$ = str$.." Font \""..t.font.."\""
If HaveItem(t, "Skin") Then str$ = str$.." Skin \""..t.skin.."\""
If HaveItem(t, "Image") Then str$ = str$.." Image "..t.image
If HaveItem(t, "Color") Then str$ = str$.." Color "..t.color
If HaveItem(t, "Mouse") Then str$ = str$.." MOUSE"
If HaveItem(t, "Center") Then str$ = str$.." CENTER"
If HaveItem(t, "Duration") Then str$ = str$.." Duration "..t.duration
SendRexxCommand("MAGICBEACON", str$)
EndFunction
p_MOSToast("Hello", {mouse=true, font = "Lux/26", Skin="Woo0t", image="Connected"})
But SendRexxCommand() seems to have a problem with quotes in the command!?
Although I use a backslash quote to surround the text with quotes, it only works if you don't use spaces in your text!
