searching an ati x800xt
    Posts: 21 from 2015/12/17
    hello,
    my x800 in my g5 has memory errors. i am searching for an replacement.
  • »04.02.19 - 18:57
    Posts: 847 from 2004/2/8
    Do you really need OSX dual boot? If not then maybe it's a good idea to look for an X1950 AGP?
  • »04.02.19 - 19:33
    g01df1sh
    Posts: 36 from 2015/5/28
    Is G5 AGP or pci express ?
  • »07.02.19 - 20:45
    g01df1sh
    If its AGP then is this not any good
    https://www.ebay.co.uk/itm/ATI-Radeon-X800-Pro-256MB-AGP-Graphics-Card/223367120303?hash=item3401b7c5af:g:JGsAAOSw9JpcWIxP:rk:1:pf:0
  • »07.02.19 - 20:46
    Hello,
    thank you for the response.
    I have an AGP System.
    The Radeon from the ebay link, is this really compatible with the g5 ?
    I tought only mac versions will work.
    My current x800 is an original mac version with this additional pins for power
    would this card also work ?
    https://www.ebay-kleinanzeigen.de/s-anzeige/sapphire-radeon-x1950-pro-512mb-agp-grafikkarte/1022816749-225-8098
    [ Editiert durch frickler 08.02.2019 - 07:11 ]
  • »08.02.19 - 07:07
    ernsteiswuerfel
    Posts: 250 from 2015/6/18
    It will work under MorphOS (not under OS X), but without Mac-BIOS the G5 won't show any screen output until you reach the MorphOS desktop. Which means no access to OpenFirmware at bootup, no boot menu.
    Talos II Secure Workstation. [Gentoo Linux] | PMac G5 7,3. PBook G4 5,8. [MorphOS 3.11 / Gentoo Linux] | A1200. ACA-1233, Indivision AGA Mk2. [Amiga OS 3.1.4]
  • »08.02.19 - 13:48
    hey that is cool.. i dont need osx.
    Great !
    So i will order the x1950 radeon
  • »08.02.19 - 14:20
    Posts: 10134 from 2003/5/22
    No.
    Indeed.
  • »08.02.19 - 23:06
    You're talking about X800, or X1950? If you meant X800 then it's not true.
  • »09.02.19 - 06:32
    ernsteiswuerfel
    I was talking about the Sapphire X1950 of the last ebay link. Had one of that for a short period of time on my G5. But I went back to a Mac-BIOS card 'cause of the OF boot prompt/menu.
  • »09.02.19 - 10:20
    my 1950pro arrived today, put it in the g5 and it worked directly without problems.
    I only had to build a power adapter. No more graphic errors !
    [ Editiert durch frickler 14.02.2019 - 15:24 ]
  • »14.02.19 - 15:24
    Posts: 4717 from 2009/1/28
    No, that isn't right. That only works with R500 and above based cards (not with R400s like the X800XT).
    Glad to hear you went with the X1950. That is the same type of card Bigfoot developed the R500 driver with.
    [ Edited by Jim 16.02.2019 - 20:10 ]
  • »17.02.19 - 01:08
    ernsteiswuerfel
    Which is what I clarified in #10. ;-)
  • »17.02.19 - 09:44
