Posts: 389 from 2003/2/25
Hi Papio,
here is a litte arexx script to change the skin of any screen.
The change will take effect immediatly, if you want it to be permanently (after reboot),
just remove the command around the last "Copy" command, then it will be copied
to envarc: too!
Copy this script to rexx:, then call it like this:
rx rexx:ChangeSkin.rexx Ambient Nox
* Change the skin of a screen in env:mui/screens.txt
* by Thomas Igracki
* The change will take effect immediatly, if you want it to be permanently (after reboot),
* just remove the command around the last "Copy" command, then it will be copied
* to envarc: too!
* Usage: rx ChangeSkin.rexx <screen name, f.e. Ambient> <new skin>
* Example: rx ChangeSkin.rexx Ambient Nox
* 31-Jan-2019: v1.0
OPTIONS RESULTS
PARSE ARG Screen" "newSkin
IF Screen = "" | newSkin = "" THEN
Say "Usage: rx ChangeSkin.rexx <screen name, f.e. Ambient> <new skin>"
ELSE; DO
IF ~EXISTS("MOSSYS:Prefs/Skins/"newSkin) & ~EXISTS("SYS:Prefs/Skins/"newSkin) THEN
Say "The skin '"newSkin"' didn't exists!"
ELSE; DO
IF Open(fhIn, "env:mui/screens.txt", "R") THEN; DO
IF Open(fhOut, "t:new_screens.txt", "W") THEN; DO
found = 0
DO UNTIL EOF(fhIn)
line = ReadLn(fhIn);
PARSE VAR line "N="scr" "dummy" S="skin" "dummy2
IF scr = Screen THEN; DO
found = 1
line = "N="scr" "dummy" S="newSkin" "dummy2
oldSkin = skin
END
WriteLn(fhOut, line)
END
Close(fhIn)
Close(fhOut)
IF found=0 THEN
Say "Didn't found the screen '"Screen"'!"
ELSE; DO
Say "Found the screen '"Screen"'!"
Say "Changed the skin from '"oldSkin"' to '"newSkin"'."
SHELL COMMAND "Copy t:new_screens.txt env:mui/screens.txt"
SHELL COMMAND "Delete >NIL t:new_screens.txt"
/* remove these comment if you want to save the new screens!
SHELL COMMAND "Copy env:mui/screens.txt envarc:mui/screens.txt"
END
END
END
END
END
Edited to check, if the skin exists!
