Posts: 1476 from 2012/11/10
igracki wrote: I already said that my Install script isn't a script for the Installer!
It's a simple Amiga DOS script which asks if you want to install/upgrade and then copies the needed files to the correct place!
Of course it's not, I should have realised with the more word like syntax, apologies for that.
igracki wrote: So no need to change any tooltype!
That seemed to be necessary, as double-clicking on it just opened the script file to view it as a text file, but adding the IconX tooltype fixed it for me, and ran it as you intended it to, though I suppose I could have just "executed" it?
Igracki - Screenbar module called
WebRadio - available anywhere to download
igracki wrote: No, it's not available yet. It's working good though it needs just some love to the settings;)
Well that would be nice to see implemented once it's fully stable, and functional, expecially if it can download/save any live radio/music stream, as a WAV, OGG or MP3, etc., and maybe in the future other suitably streamable media.
