preparing CompactFlash partitions for real amiga
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello guys, i'm asking here because i have been following numerous tutorials and cant get it working for me using winuae.Im using the correct scsi.device but i cant get the full 16gb of the card, so i thought of preparing it directly under morphos. Being the only thing needed the partition setup and the format, could be possible to get it prepared on my mac mini with morphos?. The reason i ask is because being morphos a native amiga filesystem, maybe it could get it going. At the moment i'm stuck with a 16gb card and only 8gb getting recognized.
    Thanks in advance!!!!
  • »14.12.18 - 11:31
    _ThEcRoW
    Seems it is possible as i'm reading about it on the mos wiki. Perfect.
  • »14.12.18 - 12:53
    _ThEcRoW
    Well, i tried, but it is encountering read/write errors. Once created the partitions with hdconfig, they not appear on ambient. Its getting on my nerves now. I checked under windows and the card is ok, so what could be the reason i cannot format properly in pfs or sfs for amiga?
  • »14.12.18 - 14:56
    _ThEcRoW
    No, when i mean is ok under windows i mean after cleaning with diskpart. Of course amiga partitions not show on windows and says device needs format.
  • »14.12.18 - 17:39
    Posts: 2026 from 2003/2/24
    And did you format them between these steps? They don't appear on Ambient before you use the Format tool to format them after creating the partitions. And maybe unplug+replug the card reader between partitioning and formatting.
    And when you get the read/write errors?
  • »14.12.18 - 18:32
    _ThEcRoW
    Yeah, they didn't show even after the formatting. I will keep investigating when i have more time this weekend.
  • »22.12.18 - 13:05
