Disk Master II bug
    Templario
    Posts: 264 from 2012/4/28
    I have found one bug or problem in this 68k tool copying files with names with more of 29 letters, the program doesn't copy, rename eveb delege them, is there any patch for this?
    Amiga 500 with ROMs 1.3-2.05 and M-Tec AT 500 with hard disk and 4MB Ram.
    WinUAE + original OS 3.5&3.9
    Sam440ep 800 MHZ + OS 4.1 F.E.
    Sam460ex 1 GHz + OS 4.1 F.E.
    MacMini 1.5 GHz + MorphOS 3.11
    PowerBook G4 1.65 + MorphOS 3.11
  • »16.09.18 - 15:50
    shaf
    Posts: 13 from 2013/6/11
    which version of DiskMaster II are you using?
  • »24.09.18 - 00:15
    Templario
    The version 2.2b13
  • »26.09.18 - 09:59
    Templario
    Well, because I have this version under WinUae.
    But it where is available?
  • »26.09.18 - 11:31
    Templario
    koszer escribió:
    Thank you, it is curious, under AmigaOS 4 I use the last version 2.6 but under AmigaOS 3.9 and MorphOS the old version.
  • »26.09.18 - 16:09
    Posts: 10134 from 2003/5/22
    Last OS4 version is 2.7beta11.
  • »26.09.18 - 18:53
    Templario
    I haven't so updated my Sam440ep with OS4.
  • »27.09.18 - 11:22
