Problems copying files inside of USB
    Templario
    Posts: 261 from 2012/4/28
    I have problems when copy files inside of USB drives to use in other systems but with MorpOS not, it is as change anything in drives with fat 32, for example I had problems with an USB that I use with AmigaOS4 the os doesn't recognize the drive until that I reformated the drive also with one sd card under Windows, this problem I could see copying files with drap and drop icons.
    Its is a bug or other problem?
    Amiga 500 with ROMs 1.3-2.05 and M-Tec AT 500 with hard disk and 4MB Ram.
    WinUAE + original OS 3.5&3.9
    Sam440ep 800 MHZ + OS 4.1 F.E.
    Sam460ex 1 GHz + OS 4.1 F.E.
    MacMini 1.5 GHz + MorphOS 3.11
    PowerBook G4 1.65 + MorphOS 3.11
  • »16.09.18 - 15:56
