Odyssey and Google Captcha
    Jeckel
    Posts: 133 from 2007/3/11
    Hi there,
    I was stuck several times with these annoying Captcha not working with Odyssey (and really really stuck since I don't always have anything else than MorphOS, notably when traveling).
    Here they are:
    https://www.google.com/recaptcha/api2/demo
    Is there a way to make them work? Any trick?
  • »06.09.18 - 08:40
    Posts: 2026 from 2003/2/24
    They do work if you spoof as iPad (reload the page if you change the spoofing on the fly).
    It still feels difficult sometimes and I haven't got through with those street signs ever, but when you get those slower rendering ones (buses, store fronts, etc), then you usually succeed sooner or later. Just be patient and keep going and you can do it :)
  • »06.09.18 - 09:29
    Jeckel
    Thx, your trick worked for one of the website which was blocking me!
    But no clue for the other one. :-(
  • »06.09.18 - 16:54
