Posts: 1370 from 2003/2/15
If you keep an installation of MacOS on your system, you could reboot and use that to access Skype at least (via leopard-webkit, for instance).
For unknown reasons, Skype fails to properly connect to Microsoft's messaging servers when Odyssey is being used. Officially, Skype Web only supports the Microsoft Edge and Google Chrome web browsers so cross-browser compatibility does not appear to be a priority for its developers.
