GCC6 missing from SDK source
    Nadir
    Posts: 157 from 2003/3/17
    Thanks for reporting this. Is the diff file missing? If so, this is a mistake in the automatik generation of the source archives and i think nobody noticeded. We will fix this for the next SDK but if you need the diff in the meanwhile, please let me know.
  • »25.08.18 - 10:05
    Marlon
    Posts: 31 from 2018/2/9
    Thank you for getting back so quickly!
    In the archive there is three gcc folders: gcc (2.95), gcc4 and gcc5
    each of them contains the source + patch/diff files.
    The gcc6 folder is missing, and so is the patch. So if you can send me the patch somehow that would be great! =)
    Thanks!
  • »25.08.18 - 11:05
    BSzili
    Posts: 559 from 2012/6/8
    It would be great if the GCC6 patches used in the April 2018 would be released, so I could build a cross compiler. Maybe they could be uploaded separately for the time being?
  • »12.12.18 - 08:44
    Posts: 2971 from 2003/3/5
    Unfortunately the next SDK release is taking a bit longer than I’d wish it would. Hopefully we’ll be able to release something around early Q1/19.
  • »13.12.18 - 08:48
