No Fan working PowerBook G4 1.67 15" model 5,6 - A1106 -
    sergius
    Posts: 32 from 2005/12/6
    I upgraded from morphos 3.10 to morphos 3.11 and fans doesn't work.
    I tried to change fan settings but the temperature reached the 62 degrees without any reaction from cooling system.
    When I reset the pmu, holding power bouton for 10 seconds, fans work at full speed, so they are not dead.
    An idea?
    [ Edited by sergius 05.08.2018 - 16:41 ]
  • »05.08.18 - 11:59
    Posts: 1697 from 2003/3/5
    That's correct. The fans are only handled in revision E (DDR2) of PowerBooks at the moment.
  • »06.08.18 - 01:06
    sergius
    Hi jacadcaps, thank you for the answer.
    Can you confirm to me the good powerbook model with fan control support is
    M9969LL/A, A1138.
    Thanks
  • »06.08.18 - 10:38
    Yes, it works on that one. I am hoping to fix support for other models later on too...
  • »07.08.18 - 14:29
