WLAN USB - ibook G4
    Posts: 1 from 2018/7/25
    Hello! I am testing Morphos on a iBook G4 - 2003 - no wifi card onboard.
    Is there any USB Wifi dongle that works on morphos? Thanks in advance.
    Regards,
    Francisco
  • »25.07.18 - 23:18
    Posts: 12074 from 2003/5/22
    Unfortunately not.
  • »25.07.18 - 23:56
    Posts: 1246 from 2004/2/8
    Not really, but if it's a 2003 model then you can get an Apple A1027 Airport Extreme card for about 5-10 EUR (just make sure it's A1027 and not A1026, as those don't work with MorphOS), just plug it in place, attach the antenna cable and off you go.
  • »26.07.18 - 07:33
