Screen grab with key shortcut
    imax
    Posts: 41 from 2004/9/20
    Hello !
    Please remind me of a screen grabber with a function of keyboard shortcuts.
  • »17.07.18 - 22:03
    Develin
    Posts: 100 from 2003/4/19
    imax wrote:
    Hello !
    You can use the grabber utility that comes with MorphOS with the screenbar module active, then you'll get hotkeys for the grabbing.
    Or if you like to try mine own grabber tool =) It also has user defined hotkeys : SnapIT
  • »17.07.18 - 23:10
    imax
    Well done !
    Big thank to you. Nice utility .Now i can write a post about replacing 18650 batteries in my MacBook
  • »18.07.18 - 06:00
    Posts: 2026 from 2003/2/24
    More about the Grabber screenbar module which comes with the MorphOS by default... if you have it enabled, the default keyboard shortcuts are: ctrl-lalt-g to grab a screen, ctrl-lalt-w to grab a window, and ctrl-lalt-r to grab a rectangle. You can configure these from the screenbar settings (RMB over the screen depth gadget -> Settings -> Grabber).
  • »18.07.18 - 06:22
    imax
    Thank you! Аll attempts to use shortkey at grabber work failed.
  • »19.07.18 - 04:57
