Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Cron like?
asrael22
# 1
Posts: 404 from 2014/6/11
Hi.
I'm looking for some Cron like software that I can use to start some scripts on a timely basis.
I've looked at EZCron. Maybe I didn't try hard enough but I wasn't able to install that on MorphOS.
If you say, it works, I'll try again.
But, is there something else?
Manfred
10.07.18
19:41
Korni
# 2
Posts: 471 from 2006/2/23
WaitX
10.07.18
19:50
asrael22
# 3
Korni wrote:
WaitX
Yeah, that would do.
10.07.18
19:55
Tom01
# 4
Posts: 179 from 2009/9/20
CyberCron
It works like the original Cron.
[ Edited by Tom01 12.07.2018 - 17:32 ]
11.07.18
16:14
Posts: 2026 from 2003/2/24
+1 for
WaitX
from here too.
Just put "Run >NIL: WaitX ALWAYS ..." lines to your S:user-startup for every command/script you need to be executed at certain intervals. Simple, easy, less likely to have bugs, and comes with the OS :)
jPV's MorphOS pages
12.07.18
06:11
