ppc-morphos-gcc cross compiler for OSX
    Intuition
    Posts: 1113 from 2013/5/24
    I'm currently trying to build the cross compiler suite on OSX 10.9 but it fails when try to build binutils. :/
    I'm using gcc-4.9 not clang and i've modified Bigfoot's setup-cross-sdk.sh to use gnu-tar and a remove a couple other linux-isms that made the script fall over.
    It now gets as far as trying to build binutils but fails at this point
    creating Makefile
    if [ -n "" ] && [ ! -d pic ]; then
    mkdir pic;
    else true; fi
    touch stamp-picdir
    echo "# !Automatically generated from ../../libiberty/functions.def"
    "- DO NOT EDIT!" >needed2.awk
    grep '^DEFVAR(' < ../../libiberty/functions.def
    | sed -e '/DEFVAR/s|DEFVAR.([^,]*).*|/1/ { printf "#ifndef NEED_1\n#define NEED_1\n#endif\n" }|'
    >>needed2.awk
    grep '^DEFFUNC(' < ../../libiberty/functions.def
    | sed -e '/DEFFUNC/s|DEFFUNC.([^,]*).*|/1/ { printf "#ifndef NEED_1\n#define NEED_1\n#endif\n" }|'
    >>needed2.awk
    gcc -c -m32 -O3 -I. -I../../libiberty/../include -I../../libiberty ../../libiberty/dummy.c 2>/dev/null
    make[1]: *** [dummy.o] Error 1
    make: *** [all-libiberty] Error 2
    Any ideas? I'm tired and annoyed so i'm off to have a smoke now.
  • »28.09.14 - 12:56
    Posts: 3214 from 2003/3/5
    That's where you should restart. I am pretty sure the binutils will only build with gcc 2.95.
  • »28.09.14 - 15:59
    Intuition
    Thanks Jaca, will give it a try later.
  • »28.09.14 - 17:36
    Intuition
    Building gcc 2.95.3 for OSX is even more sanity destroying. :/
    I'm surprised no one seems to have built an OSX hosted cross compiler before.
    Zerohero's site is down but i think he only had Linux hosted cross compilers anyway.
  • »29.09.14 - 06:43
    AmiS
    Posts: 6 from 2003/6/27
    I made it. I build current 4.4.5 gcc from morphos SDK under OSX.
    also i build flexcat utility
    enjoy
    http://amis.su/files/cross-gcc-4.4.5-ppc-morphos-osx.tar.gz
  • »27.04.15 - 06:23
    ausPPC
    Posts: 543 from 2007/8/6
    I know this is a little off-topic but, as gcc has matured, have the advances been x86 specific or are they also seen on other architectures?
  • »03.05.15 - 22:27
    AmiS
    I have osx10.10 on x86 macs here. I build GCC Using clang. This build for x86 macs only.
  • »04.05.15 - 04:47
    Posts: 12408 from 2003/5/22
    You can read up on the changes between version 4.4.5 as available for MorphOS and the most recent version:
    http://gcc.gnu.org/gcc-4.5/changes.html
    http://gcc.gnu.org/gcc-4.6/changes.html
    http://gcc.gnu.org/gcc-4.7/changes.html
    http://gcc.gnu.org/gcc-4.8/changes.html
    http://gcc.gnu.org/gcc-4.9/changes.html
    http://gcc.gnu.org/gcc-5/changes.html
    There, the changes are classified into language-specific, ISA-specific and OS-specific ones.
  • »04.05.15 - 09:44
    munk
    Posts: 94 from 2006/3/27
    Any ideas?
    Modifiying functions.def is only necessary for GCC 2.95.x.
    The problem is not the host system, but the GCC version. 2.95.x does not like building on a 64-bit host system. Especially the ppc backend has its problems. Apparently even Apple did not build 2.95.x as a 64-bit executable. However, building as a 32-bit target using -m32 in $(CC) could work.
  • »04.05.15 - 17:15
  • Leo
    Leo
    Posts: 419 from 2003/8/18
    enjoy
    Just found out your archive: thanks! I couldn't build it myself.
    After scratching my head trying and failing to create the cross-gcc on macOS and Linux, maybe it would be a good idea to officially release cross-dev tools ready to be used?
    [ Edited by Leo 11.06.2018 - 23:56 ]
  • »11.06.18 - 20:37
    Yes. Totally!
  • »14.06.18 - 09:38
