Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
General Discussion
PicShow don't start on MorphOS 3.10 ?
Papiosaur
# 1
Posts: 2042 from 2003/4/10
Hello all,
Did you have tested PiShow on MorphOS 3.10 ?
I have an illegal instruction here...
Worked fine with 3.9
Thanks for your returns
[ Edité par Papiosaur 02.06.2018 - 16:19 ]
Easy2Install
www.meta-morphos.org
www.morphos-storage.net
02.06.18
15:18
emeck
# 2
Posts: 168 from 2014/7/15
@papiosaur
Works fine here with MOS3.10. I have PicShow version 31.457
PowerBook 5.8 MorphOS 3.18
Mac Mini MorphOS 3.18
02.06.18
15:36
Papiosaur
# 3
Hi emeck,
i will try to remove third party so
Thanks a lot for your quick answser !
Easy2Install
02.06.18
15:38
