Increase UI font size
    mattybigback
    Posts: 2 from 2018/4/24
    Hi All
    Just installed MorphOS 3.10 on my Mac Mini G4 and I'm impressed so far. I've got the screen resolution set to 1280x1024 as that's the only resolution that my monitor can handle, but the fonts are all so small that I can barely read them.
    Is there a way I can increase the font sizes without reducing the screen resolution?
    Thanks
    Mac Mini G4 1.5GHz
    1GB RAM
    80GB HDD
    It's not the size, it's how you use it
  • »24.04.18 - 23:07
    deez
    Posts: 53 from 2003/5/28
    mattybigback wrote:
    Hi All
    Thanks
    Open MorphOS Preferences and click on "Font" in User Interface.
  • »24.04.18 - 23:16
    mattybigback
    Thanks for that. I've still got a few things that are too small to read though, like the status bar in the Ambient file explorer. I've tried tweaking the settings in MUI and it's getting closer.
    Mac Mini G4 1.5GHz
    1GB RAM
    80GB HDD
  • »25.04.18 - 00:18
    deka
    Posts: 136 from 2013/2/12
    This is teh default font used by the system. Needs a restart to apply it.
  • »25.04.18 - 13:00
