HowTo: Freespace 2 in 1024x768
    Cego
    Posts: 584 from 2006/5/28
    As you have already noticed the Powerbook G4 can only display its native resolution of 1440x960.
    So games running at a much lower resolution would end up appearing as a small box on the screen.
    Now i found a way to play Freespace 2 in a higher resolution of 1024x768.
    1. Download unshield from aminet and copy it to c:
    http://aminet.net/util/arc/unshield05-mos.lha
    2. Put your Freespace 2 CD1 into your cd drive.
    3. Open up a shell and cd to the desired destination drawer and type in
    unshield -j -g "High Res Files" x /Freespace2_1/DATA1.CAB
    4. Now you will have to copy the file "sparky_hi_fs2.vp" to your Freespace2/data directory.
    5. At last you will have to edit freespace2.ini file in the main directory and replace videocard=OpenGL (640x480) with videocard=OpenGL (1024x768)
    Now Freespace2 should start at a higher resolution. Have Fun!
    [ Edited by Cego 12.08.2013 - 14:09 ]
    Powerbook G4@1,67GHz, 2GB DDR2 Ram, Radeon 9700, 60GB SSD, MorphOS 3.7
    PowerMac Dual G5 @2.3GHz, 4GB DDR Ram, Radeon 9600XT, 2x250GB HD, MorphOS 3.7, MacOS X Leopard 10.5.8
  • »12.08.13 - 13:36
    Cego
    [ Edited by Cego 12.08.2013 - 13:43 ]
  • »12.08.13 - 13:42
    Posts: 9956 from 2003/5/22
    Just for the record, this part has also been covered 7 years ago by the news item and comments to be found there:
    https://morph.zone/modules/news/article_storyid_1107.html
  • »12.08.13 - 14:15
    Cego
    yeah, but the point here is the actual description of how to do that :)
    that news item gave me the idea to figure that out and make this how to.
  • »12.08.13 - 14:32
    > the point here is the actual description of how to do that :) that news
    In one of the comments, kiero said he would upload a script that was able to extract the high resolution data. I guess this never happened then.
  • »12.08.13 - 14:42
    Cego
    yeah, i couldnt find that script anywhere, so i had to do it on my own and share it with the community. i think a few people, who'd also love to play freespace 2 on their PB G4 might benefit from it.
  • »12.08.13 - 16:26
    asrael22
    Posts: 368 from 2014/6/11
    Just a heads up, as it's already 5 years old.
    It still works.
    Manfred
  • »16.04.18 - 07:38
    Korni
    Posts: 375 from 2006/2/23
    Now you can set a custom resolution on a powerbook too.
  • »16.04.18 - 09:44
