Dekadence's demo for MorphOS at Revision 2018
  • MDW
    MDW
    Posts: 451 from 2003/7/26
    Revision 2018 has been just ended. The party provided us one demo for MorphOS - "Version: Operators" by Dekadence. Unfortunately I can't find the demo in executable version. Result from the party (http://www.pouet.net/party.php?which=1550&when=2018) doesn't contain the demo. I hope the results will be updated soon.
    Comment from the authors before the demo:
    "AMIGAAAAAAAAAAiiiiiish!!!11 (MorphOS)
    Runs with early 2000 G4 PPC computers.
    Put your shitty iBooks to good use."
    There is saved stream from wild competition. The demo for MorphOS starts from 19:36.
    https://youtu.be/s6a1InnD31k?t=19m36s
    Has someone know if the executable version of the demo is available for download?
    Congratulation Dekadence! Thank you for MorphOS support.
    [ Edited by MDW 02.04.2018 - 14:58 ]
  • »02.04.18 - 13:15
    ausPPC
    Posts: 543 from 2007/8/6
    Nice. I'm glad that anyone is still doing anything like this for Amiga / MorphOS. But I couldn't shake the impression that the entire thing was an intro for something else - like opening credits or something, it felt like the actual demo never started...
  • »02.04.18 - 18:26
    deez
    Posts: 53 from 2003/5/28
    Executable available.... look inside archive of video version. :-)
  • »02.04.18 - 18:48
  • MDW
    MDW
    You are right. Results on pouet.net have been already updated and now the exec is available. Thank you for the info!
  • »02.04.18 - 19:10
    defender
    Posts: 247 from 2011/4/24
    after starting "engine" I got this output from ambient:
    [0:00.000] 1B7DEB58 system/thread/thread.c:loadOpenGlMainContext():165:
    ERROR: Functionality not implemented! context:'0x0x1c5ed8cc'
    [0:00.000] 1B7DEB58 system/extensions/gl/gl.c:openGlExtensionsInit():213:
    ERROR: Could not load GLSL extensions!
    [0:00.000] 1B7DEB58 system/extensions/gl/gl.c:openGlExtensionsInit():277:
    ERROR: Could not load FBO extensions!
    and the demo crashes my system, so i have to reboot - anyone else running into that
    problem?
    (g4; 1,25GHz; 1,5GB ram; 64Mb Radeon)
  • »02.04.18 - 19:34
    beworld
    Posts: 590 from 2010/2/10
    sames errors here but dont crash, it's working well (on my G5)
    IMac G5 2.1,PowerBook G4 1.5,MacMini 1.5, PowerMac G5 2.7 died !!!
    My MOS ports
  • »02.04.18 - 19:50
  • MDW
    MDW
    I get the same output on CLI but demo starts. The demo crashes at the end (reboot necessary).
  • »02.04.18 - 20:18
    waldiamiga
    Posts: 90 from 2007/7/25
    Add icon to exe file. Application is mediating at the end demo.
    MorphOS.pl
    Core i7 Notebook|WinUAE 3.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 6.x.x
  • »02.04.18 - 21:35
    defender
    So it seems to be a fault inside the -engine- thanks.
  • »02.04.18 - 21:52
    waffle
    Posts: 1 from 2018/4/4
    Hello from the creator,
    Sorry for the crash-at-end bug. I have the same issue but didn't have time to fix it due to the risk of missing compo deadline. The issue is most likely quite clear so I'll fix it at some point. :)
    Thanks for the nice OS (and special thanks for britelite for the HW&IT support!). This was my first MorphOS release and first time using the OS. Expect more releases in the future.
    Br,
    Waffle
    P.s. In case you're interested making demos: the engine is scriptable and you can make your own prods using javascript/c. I'll probably make a proper release of the engine with source code and documentation at later point in time.
  • »04.04.18 - 10:58
  • MDW
    MDW
    ... and first time using the OS.
    Are you new user of MorphOS? Really? Great! Welcome in the community.
    Have you used AmigaOS before MorphOS?
    Great! I can't wait for next productions.
  • »04.04.18 - 19:18
    Posts: 9 from 2018/4/8
    WOW awesome!
    Great stuff mate, I would love to do that.
  • »09.04.18 - 05:01
