Posts: 2021 from 2003/2/24
Remember to use the CLONE option if using the Copy command.
And if you have SDK installed, use for example
MirrorCopy to copy it. MirrorCopy handles the soft-links automatically.
If using SFS formatted USB disk or similar, I'd copy/mirrorcopy files to it, and then run
MirrorCheck to check file integrity. And repeat when it's been copied to the target system.
I usually do it that I run MorphOS installer on a new machine to get the partition layout properly, but then I format the newly made installation and use the installation CD to copy a backup from external media to the fresh partitions.
And yeah, RAWDISK: copy could be an interesting option.
[ Edited by jPV 05.04.2018 - 19:55 ]
