Bug in glIsEnabled()?
  • MDW
    MDW
    Posts: 223 from 2003/7/26
    I noticed somethig strange. I can't check if scissor is enabled. Function glIsEnabled() always returns 0 if I use parameter GL_SCISSOR_TEST. If I use glIsEnabled() with other parameter (e.g. GL_FOG), the function will return correct value.
    Please look at this simple test:
    glEnable(GL_SCISSOR_TEST);
    printf("scissor enabled: %d\n", glIsEnabled(GL_SCISSOR_TEST));
    glDisable(GL_SCISSOR_TEST);
    printf("scissor disabled: %d\n", glIsEnabled(GL_SCISSOR_TEST));
    glEnable(GL_FOG);
    printf("fog enabled: %d\n", glIsEnabled(GL_FOG));
    glDisable(GL_FOG);
    printf("fog disabled: %d\n", glIsEnabled(GL_FOG));
    RESULT:
    scissor enabled: 0
    scissor disabled: 0
    fog enabled: 1
    fog disabled: 0
    Is it a bug in TinyGL? Known bug?
    I use MorphOS 3.9 with MOS SDK 3.9 on PowerBookG4 (15-inch, 1,67 GHz).
  • »26.01.17 - 20:33
    Posts: 368 from 2007/10/23
    FYI officially reported as #0003511
    Pegasos II G4: MorphOS 3.9, Zalman M220W
    Power Mac G3: OSX 10.3 · PowerBook 5,8: OSX 10.5, MorphOS 3.10
  • »13.01.18 - 04:18
  • MDW
    MDW
    Great! Thank you for the information.
  • »13.01.18 - 09:44
    Well, there's no official 3D maintainer,
    so you have also to kick every developer from time to time ;-) ;-)
    [ Editiert durch polluks 15.01.2018 - 03:11 ]
  • »15.01.18 - 03:06
    Posts: 9738 from 2003/5/22
    Kiero?
  • »15.01.18 - 22:40
    Posts: 4593 from 2009/1/28
    Kiero?
    Who can be really difficult to get in touch with.
  • »16.01.18 - 09:56
