GIT for MorphOS?
  • MDW
    MDW
    Posts: 451 from 2003/7/25
    Is there any chance to GIT for MorphOS?
  • »17.02.17 - 19:50
    sTix
    Posts: 39 from 2003/12/7
    Perhaps someone could approach the guy behind this:
    sgit for os4
    Seems like a nice project...
  • »17.02.17 - 23:50
    Posts: 778 from 2007/10/23
    Version 1.6.0.2
    [ Editiert durch polluks 18.02.2017 - 01:08 ]
  • »18.02.17 - 00:07
    Posts: 2968 from 2003/3/5
    There are no plans to make a client part of the SDK right now.
  • »18.02.17 - 12:28
    Jupp3
    Posts: 1193 from 2003/2/24
    The sad reality is, GIT isn't very portable, it's practically more or less "posix-only" (and MorphOS isn't 100% compatible)
  • »21.02.17 - 18:28
    libgit2 seems fairly portable, actually. Wish I had time to spare.
  • »21.02.17 - 23:05
    connor
    Posts: 570 from 2007/7/29
    Just drop this fancy useless Exposé stuff and do git instead :-)
  • »22.02.17 - 10:41
  • MDW
    MDW
    In my opinion the Exposé is very useful. AmigaOS/MorphOS/AROS needs a mechanism for managing windows.
    However after Exposé I would like to get GIT client for MorphOS. :-)
  • »23.02.17 - 09:41
  • pOS
    pOS
    Posts: 216 from 2003/11/14
    Tried git. Using a local repository works.
    But I cannot clone a remote repository.
    I created usr:share/curl and copied my ca-cert bündle from OWB to this Location
    Ram Disk:> git clone "https://myusername:mypassword@github.com/myusername/myrepository"
    Initialized empty Git repository in /RAM/testrep/.git/
    fatal: https://myusername:mypassword@github.com/myusername/myrepository/info/refs download error - error:0D0C5006:asn1 encoding routines:ASN1_item_verify:EVP lib
    Anyone been succesful to clone a github repository ?
    BTW Code:
    git config http.sslVerify false
    didn't help...
    [ Edited by pOS 21.10.2017 - 02:02 ]
  • »20.10.17 - 23:11
  • pOS
    pOS
    the reason is probably this:
    Starting June 7th, 2011, GitHub will no longer support fetching over
    Git's "dumb" HTTP transport mechanism. This won't effect you unless
    you're running a git version prior to v1.6.6 and fetch using a http
    remote URL.
    I also tried ftp, but then git does nothin at all and wait, as long as I press ctrl C
  • »21.10.17 - 00:44
  • pOS
    pOS
    Seems, 7 years ago someone tried to port a newer git version:
    https://github.com/vidarh/Git
    No binaries for download there though...
  • »21.10.17 - 12:17
    Vidar Hokstad is still active, ask him :)
    Well, 1.7.3 is not so interesting anymore...
  • »22.10.17 - 14:33
    connor
    I thought about that again. What is missing in MOS to be 100% posix compatible? In former times it was often mentioned that AmigaOS was posix compatible, so I always thoutht it was 100%. so I also thought it was the same in MOS.
    Would it be "easy" to port git to MOS if MOS was 100% posix compatible?
  • »02.01.18 - 14:20
    Posts: 2231 from 2003/2/24
    I think the most common issue is fork() which doesn't really work without virtual addressing.
    Implementing this would break the whole Amiga messaging API so that not an option.
    Might be possible to run such stuff under sort of emulation/virtualization but that would either cost to much performance or manpower.
  • »02.01.18 - 14:43
    Nope, it's only used once in the unit test, see here.
  • »03.01.18 - 16:07
    Posts: 1 from 2018/10/20
    Git client is included in current MorphOS SDK
    http://morphos-team.net/downloads ->
    MorphOS Software Development Kit
    MorphOS 3.12 SDK - April 2018 - Download
  • »20.10.18 - 18:10
  • pOS
    pOS
    Is there a chance to get a libgit2 port as a shared library ?
    https://libgit2.org/
    states, that it is:
    - pure C
    - compiles without any dependencies
    - is 100% cross-platform (and Amiga is explicitly mentioned here, too)
  • »24.01.21 - 02:10
    What would be the goal of such port when the shell client works just fine?
  • »24.01.21 - 02:49
    Samurai_Crow
    Posts: 152 from 2009/12/10
    For comments regarding graphical Git front-ends see this post and comment in the new thread. Git exists for MorphOS now.
  • »26.01.21 - 15:36
