G4 vs. G5
    Posts: 80 from 2017/9/10
    > on document is explained the ddr3 on qoriq will not go faster than 3.5 gb/s like a ddr 400
    On which page?
    Page 9 , data rate
  • »15.09.17 - 12:11
    > Optimally Configuring DDR for Custom Boards
    > http://www.nxpic.org/document/download/output/id-16447
    Loading is slow here from this link. Some faster ones directly from the NXP website:
    https://www.nxp.com/docs/en/supporting-information/DWF13_AMF_NET_T1021.pdf (August 2013)
    https://www.nxp.com/docs/en/supporting-information/DWF13_AMF_NET_T1021_Ottawa.pdf (October 2013)
    "800–2133 Mbps" according to page 9 of the document tlosm mentions.
    The documentation you've pointed to mentions a slightly slower max "800–1866 Mbps" for the T10xx.
    So he may have a point, but I doubt this is providing too much performance degradation.
  • »15.09.17 - 12:26
    i think the qoriq cant have faster ram speed because not designed for desktop use but for networking.
    freescale is just upgrading the ram controller for use the actual rams because use old one will made prize more hight for customers
    [ Edited by tlosmx 15.09.2017 - 13:42 ]
  • »15.09.17 - 12:40
    Posts: 12058 from 2003/5/22
    That's the official JEDEC spec numbers for DDR3.
    > for the T10xx.
    My first linked document (which is the same as linked by Spectre660) shows DDR3 spec, while my second linked document shows DDR3L spec instead, hence the difference in max value.
    I don't think so.
  • »15.09.17 - 13:23
    > I don't think so.
    OK, the JEDEC spec would translate into what kind of bandwidth figures?
  • »15.09.17 - 13:28
    See my Wikipedia links in comment #154.
  • »15.09.17 - 13:31
    Wow, agreed, there appears to be significant room for improvement. My bad.
  • »15.09.17 - 14:05
    my lshw
    amigaone
    description: Computer
    product: varisys,CYRUS5040
    width: 32 bits
    capabilities: smp
    *-core
    description: Motherboard
    physical id: 0
    *-cpu:0
    description: CPU
    product: e5500
    physical id: 0
    bus info: cpu@0
    version: 1.2 (pvr 8024 0012)
    clock: 800MHz
    *-cache
    description: L1 Cache
    physical id: 0
    *-cpu:1
    description: CPU
    product: e5500
    physical id: 1
    bus info: cpu@1
    clock: 800MHz
    *-cache
    physical id: 0
    *-cpu:2
    description: CPU
    product: e5500
    physical id: 2
    bus info: cpu@2
    clock: 800MHz
    *-cache
    physical id: 0
    *-cpu:3
    description: CPU
    product: e5500
    physical id: 3
    bus info: cpu@3
    clock: 800MHz
    *-cache
    physical id: 0
    *-memory
    description: System memory
    physical id: 4
    *-processor:0
    description: Power PC
    product: Freescale Semiconductor Inc
    vendor: Freescale Semiconductor Inc
    physical id: 5
    bus info: pci@0000:00:00.0
    version: 21
    width: 32 bits
    clock: 33MHz
    capabilities: pm pciexpress bus_master cap_list
    configuration: driver=pcieport latency=0
    resources: irq:482 ioport:0(size=65536) memory:c00000000-c1fffffff
    *-display
    description: VGA compatible controller
    product: Venus LE [Radeon HD 8830M]
    vendor: Advanced Micro Devices, Inc. [AMD/ATI]
    physical id: 6
    bus info: pci@0000:01:00.0
    version: 87
    width: 64 bits
    clock: 33MHz
    capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
    configuration: driver=radeon latency=0
    resources: irq:42 memory:c00000000-c0fffffff memory:c10000000-c1003ffff ioport:1000(size=256) memory:c10060000-c1007ffff
    *-multimedia
    description: Audio device
    product: Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
    physical id: 0.1
    bus info: pci@0000:01:00.1
    version: 00
    width: 64 bits
    clock: 33MHz
    capabilities: pm pciexpress msi bus_master cap_list
    configuration: driver=snd_hda_intel latency=0
    resources: irq:47 memory:c10040000-c10043fff
    *-processor:1
    physical id: 7
    bus info: pci@1000:00:00.0
    version: 21
    width: 32 bits
    clock: 33MHz
    resources: irq:481 ioport:0(size=65536) memory:c20000000-c3fffffff
    *-pci
    description: PCI bridge
    product: Integrated Device Technology, Inc. [IDT]
    vendor: Integrated Device Technology, Inc. [IDT]
    physical id: 100
    bus info: pci@1000:01:00.0
    version: 02
    width: 32 bits
    clock: 33MHz
    capabilities: pci pciexpress pm normal_decode bus_master cap_list
    resources: irq:0 ioport:1000(size=12288) memory:c20000000-c201fffff
    *-pci:0
    physical id: 1
    bus info: pci@1000:02:01.0
    version: 02
    width: 32 bits
    clock: 33MHz
    capabilities: pci pciexpress pm msi normal_decode bus_master cap_list
    resources: irq:21
    *-pci
    product: PI7C9X111SL PCIe-to-PCI Reversible Bridge
    vendor: Pericom Semiconductor
    physical id: 0
    bus info: pci@1000:03:00.0
    version: 02
    width: 32 bits
    clock: 33MHz
    capabilities: pci pcix pm pciexpress msi normal_decode bus_master cap_list
    *-pci:1
    physical id: 2
    bus info: pci@1000:02:02.0
    version: 02
    width: 32 bits
    clock: 33MHz
    resources: irq:22 ioport:1000(size=4096) memory:c20000000-c200fffff
    *-network
    description: Ethernet interface
    product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
    vendor: Realtek Semiconductor Co., Ltd.
    physical id: 0
    bus info: pci@1000:05:00.0
    logical name: eth0
    version: 06
    serial: 98:de:d0:06:12:cb
    capacity: 1Gbit/s
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8168e-2.fw ip=192.168.1.16 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
    resources: irq:46 ioport:1000(size=256) memory:c20000000-c20000fff memory:c20004000-c20007fff
    *-pci:2
    physical id: 3
    bus info: pci@1000:02:03.0
    version: 02
    width: 32 bits
    clock: 33MHz
    resources: irq:23 ioport:2000(size=4096)
    *-pci
    product: ASM1083/1085 PCIe to PCI Bridge
    vendor: ASMedia Technology Inc.
    physical id: 0
    bus info: pci@1000:06:00.0
    version: 03
    width: 32 bits
    clock: 33MHz
    capabilities: pci msi pm pciexpress normal_decode bus_master cap_list
    resources: ioport:2000(size=4096)
    *-multimedia
    description: Multimedia audio controller
    product: CMI8738/CMI8768 PCI Audio
    vendor: C-Media Electronics Inc
    physical id: 0
    bus info: pci@1000:07:00.0
    version: 10
    width: 32 bits
    clock: 33MHz
    capabilities: pm bus_master cap_list
    configuration: driver=snd_cmipci latency=128 maxlatency=24 mingnt=2
    resources: irq:20 ioport:2000(size=256)
    *-pci:3
    physical id: 8
    bus info: pci@1000:02:08.0
    version: 02
    width: 32 bits
    clock: 33MHz
    resources: irq:26 ioport:3000(size=4096) memory:c20100000-c201fffff
    *-storage
    description: SATA controller
    product: Marvell Technology Group Ltd.
    vendor: Marvell Technology Group Ltd.
    physical id: 0
    bus info: pci@1000:08:00.0
    version: 12
    width: 32 bits
    clock: 33MHz
    capabilities: storage pm msi pciexpress ahci_1.0 bus_master cap_list rom
    configuration: driver=ahci latency=0
    resources: irq:43 ioport:3000(size=8) ioport:3008(size=4) ioport:3010(size=8) ioport:3018(size=4) ioport:3020(size=16) memory:c20100000-c201001ff memory:c20110000-c2011ffff
    *-pci:4
    physical id: 10
    bus info: pci@1000:02:10.0
    version: 02
    width: 32 bits
    clock: 33MHz
    resources: irq:27
    *-scsi:0
    physical id: 8
    logical name: scsi1
    capabilities: emulated
    *-disk
    description: ATA Disk
    product: Samsung SSD 840
    physical id: 0.0.0
    bus info: scsi@1:0.0.0
    logical name: /dev/sda
    version: 6B0Q
    serial: S14CNEBCB16572V
    capabilities: removable
    configuration: ansiversion=5 logicalsectorsize=512 sectorsize=512
    *-medium
    physical id: 0
    *-scsi:1
    physical id: 9
    logical name: scsi2
    *-disk
    product: ST1000DX001-1CM1
    vendor: Seagate
    physical id: 0.0.0
    bus info: scsi@2:0.0.0
    logical name: /dev/sdb
    version: CC43
    serial: Z1D9K8LY
    configuration: ansiversion=5 logicalsectorsize=512 sectorsize=4096
    *-scsi:2
    physical id: a
    logical name: scsi3
    *-cdrom
    description: DVD-RAM writer
    product: CDDVDW SH-224FB
    vendor: TSSTcorp
    physical id: 0.0.0
    bus info: scsi@3:0.0.0
    logical name: /dev/cdrom
    logical name: /dev/cdrw
    logical name: /dev/dvd
    logical name: /dev/dvdrw
    logical name: /dev/sr0
    version: SB00
    capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
    configuration: ansiversion=5 status=nodisc
    *-scsi:3
    physical id: b
    bus info: usb@1:1.1
    logical name: scsi4
    capabilities: emulated scsi-host
    configuration: driver=usb-storage
    *-disk
    description: SCSI Disk
    product: HD154UI
    vendor: SAMSUNG
    physical id: 0.0.0
    bus info: scsi@4:0.0.0
    logical name: /dev/sdc
    serial: 801130168383
    capabilities: partitioned partitioned:dos
    configuration: ansiversion=2 logicalsectorsize=512 sectorsize=512 signature=0cd096ae
    *-volume
    description: Windows FAT volume
    vendor: MSWIN4.1
    physical id: 1
    bus info: scsi@4:0.0.0,1
    logical name: /dev/sdc1
    logical name: /media/amigaone/VERBATIM
    version: FAT32
    serial: 0000-0000
    capacity: 1397GiB
    capabilities: primary fat initialized
    configuration: FATs=2 filesystem=fat label=VERBATIM mount.fstype=vfat mount.options=rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro state=mounted
    *-network DISABLED
    physical id: 1
    logical name: dummy0
    serial: ca:8d:d6:d8:4b:ef
    capabilities: ethernet physical
    configuration: broadcast=yes driver=dummy driverversion=1.0
    my stream result on X5000/40 ubuntu mate 16.10
    STREAM version $Revision: 5.10 $
    This system uses 8 bytes per array element.
    Array size = 10000000 (elements), Offset = 0 (elements)
    Memory per array = 76.3 MiB (= 0.1 GiB).
    Total memory required = 228.9 MiB (= 0.2 GiB).
    Each kernel will be executed 10 times.
    The *best* time for each kernel (excluding the first iteration)
    will be used to compute the reported bandwidth.
    Your clock granularity/precision appears to be 1 microseconds.
    Each test below will take on the order of 125127 microseconds.
    (= 125127 clock ticks)
    Increase the size of the arrays if this shows that
    you are not getting at least 20 clock ticks per test.
    WARNING -- The above is only a rough guideline.
    For best results, please be sure you know the
    precision of your system timer.
    Function Best Rate MB/s Avg time Min time Max time
    Copy: 1328.9 0.120552 0.120398 0.120717
    Scale: 1233.6 0.130414 0.129701 0.134902
    Add: 1615.4 0.149091 0.148566 0.149944
    Triad: 1612.6 0.149026 0.148826 0.149314
    Stream 50M
    stream.50M.ppc.static
    Array size = 50000000 (elements), Offset = 0 (elements)
    Memory per array = 381.5 MiB (= 0.4 GiB).
    Total memory required = 1144.4 MiB (= 1.1 GiB).
    Each test below will take on the order of 654858 microseconds.
    (= 654858 clock ticks)
    Copy: 1292.5 0.621978 0.618969 0.624690
    Scale: 1202.7 0.669223 0.665170 0.674193
    Add: 1547.6 0.780234 0.775374 0.783583
    Triad: 1454.1 0.829659 0.825229 0.834956
    Solution Validates: avg error less than 1.000000e-13 on all three arrays
    mylspci -nnk
    lspci -nnk
    0000:00:00.0 PCI bridge [0604]: Freescale Semiconductor Inc Device [1957:0451] (rev 21)
    Kernel driver in use: pcieport
    0000:01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Venus LE [Radeon HD 8830M] [1002:682b] (rev 87)
    Subsystem: ASUSTeK Computer Inc. Venus LE [Radeon HD 8830M] [1043:7250]
    Kernel driver in use: radeon
    0000:01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] [1002:aab0]
    Subsystem: ASUSTeK Computer Inc. Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series] [1043:aab0]
    Kernel driver in use: snd_hda_intel
    1000:00:00.0 PCI bridge [0604]: Freescale Semiconductor Inc Device [1957:0451] (rev 21)
    1000:01:00.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:02:01.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:02:02.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:02:03.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:02:08.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:02:10.0 PCI bridge [0604]: Integrated Device Technology, Inc. [IDT] Device [111d:8092] (rev 02)
    1000:03:00.0 PCI bridge [0604]: Pericom Semiconductor PI7C9X111SL PCIe-to-PCI Reversible Bridge [12d8:e111] (rev 02)
    1000:05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
    Subsystem: TP-LINK Technologies Co., Ltd. TG-3468 Gigabit PCI Express Network Adapter [7470:3468]
    Kernel driver in use: r8169
    1000:06:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:1080] (rev 03)
    1000:07:00.0 Multimedia audio controller [0401]: C-Media Electronics Inc CMI8738/CMI8768 PCI Audio [13f6:0111] (rev 10)
    Subsystem: C-Media Electronic
    [ Edited by tlosmx 15.09.2017 - 16:11 ]
  • »15.09.17 - 15:09
    Dnetc P5040
    ./dnetc -bench
    distributed.net client for Linux Copyright 1997-2016, distributed.net
    RC5-72 PowerPC assembly by Malcolm Howell and Didier Levet
    Enhancements for 604e CPUs by Roberto Ragusa
    RC5-72 Altivec and OGR assembly by Didier Levet
    Please visit http://www.distributed.net/ for up-to-date contest information.
    Start the client with '-help' for a list of valid command line options.
    dnetc v2.9112-521-CFR-16021317 for Linux (Linux 4.11.3-X5000-Tlosm-LB).
    Please provide the *entire* version descriptor when submitting bug reports.
    The distributed.net bug report pages are at http://bugs.distributed.net/
    [Sep 15 15:12:52 UTC] Automatic processor type detection found
    a PowerPC e5500 processor.
    [Sep 15 15:12:52 UTC] OGR-NG: using core #0 (KOGE 3.1 Scalar).
    [Sep 15 15:13:11 UTC] OGR-NG: Benchmark for core #0 (KOGE 3.1 Scalar)
    0.00:00:16.27 [22,245,376 nodes/sec]
    [Sep 15 15:13:11 UTC] OGR-NG benchmark summary :
    Default core : #0 (KOGE 3.1 Scalar) 22,245,376 nodes/sec
    Fastest core : #0 (KOGE 3.1 Scalar) 22,245,376 nodes/sec
    [Sep 15 15:13:11 UTC] RC5-72: using core #0 (MH 2-pipe).
    [Sep 15 15:13:29 UTC] RC5-72: Benchmark for core #0 (MH 2-pipe)
    0.00:00:16.13 [5,940,470 keys/sec]
    [Sep 15 15:13:29 UTC] RC5-72: using core #1 (KKS 2-pipe).
    [Sep 15 15:13:48 UTC] RC5-72: Benchmark for core #1 (KKS 2-pipe)
    0.00:00:16.07 [6,054,956 keys/sec]
    [Sep 15 15:13:48 UTC] RC5-72: using core #2 (KKS 604e).
    [Sep 15 15:14:08 UTC] RC5-72: Benchmark for core #2 (KKS 604e)
    0.00:00:17.04 [6,182,771 keys/sec]
    [Sep 15 15:14:08 UTC] RC5-72: using core #5 (MH 1-pipe).
    [Sep 15 15:14:26 UTC] RC5-72: Benchmark for core #5 (MH 1-pipe)
    0.00:00:16.48 [5,814,945 keys/sec]
    [Sep 15 15:14:26 UTC] RC5-72: using core #6 (MH 1-pipe 604e).
    [Sep 15 15:14:45 UTC] RC5-72: Benchmark for core #6 (MH 1-pipe 604e)
    0.00:00:16.05 [5,709,840 keys/sec]
    [Sep 15 15:14:45 UTC] RC5-72 benchmark summary :
    Default core : #-1 (undefined) 0 keys/sec
    Fastest core : #2 (KKS 604e) 6,182,771 keys/sec
    [Sep 15 15:14:45 UTC] Compare and share your rates in the speeds database at
    http://www.distributed.net/speed/
    (benchmark rates are for a single processor core)
    [ Edited by tlosmx 15.09.2017 - 16:16 ]
  • »15.09.17 - 15:15
    Spectre660
    Posts: 275 from 2015/6/30
    X5000/020
    dnetc -bench
    distributed.net client for Linux Copyright 1997-2009, distributed.net
    dnetc v2.9107-515-CFR-09102403 for Linux (Linux 4.13.2-X5000-jm).
    [Sep 15 16:56:57 UTC] Automatic processor type detection did not
    recognize the processor (tag: "e5500")
    [Sep 15 16:56:57 UTC] OGR-NG: using core #0 (KOGE 3.1 Scalar).
    [Sep 15 16:57:16 UTC] OGR-NG: Benchmark for core #0 (KOGE 3.1 Scalar)
    0.00:00:16.36 [20,183,307 nodes/sec]
    [Sep 15 16:57:16 UTC] OGR-NG benchmark summary :
    [Sep 15 16:57:16 UTC] RC5-72: using core #0 (MH 2-pipe).
    [Sep 15 16:57:35 UTC] RC5-72: Benchmark for core #0 (MH 2-pipe)
    0.00:00:16.39 [5,379,355 keys/sec]
    [Sep 15 16:57:35 UTC] RC5-72: using core #1 (KKS 2-pipe).
    [Sep 15 16:57:54 UTC] RC5-72: Benchmark for core #1 (KKS 2-pipe)
    0.00:00:16.48 [5,486,483 keys/sec]
    [Sep 15 16:57:54 UTC] RC5-72: using core #2 (KKS 604e).
    [Sep 15 16:58:13 UTC] RC5-72: Benchmark for core #2 (KKS 604e)
    0.00:00:16.12 [5,586,407 keys/sec]
    [Sep 15 16:58:13 UTC] RC5-72: using core #5 (MH 1-pipe).
    [Sep 15 16:58:32 UTC] RC5-72: Benchmark for core #5 (MH 1-pipe)
    0.00:00:16.73 [5,269,122 keys/sec]
    [Sep 15 16:58:32 UTC] RC5-72: using core #6 (MH 1-pipe 604e).
    [Sep 15 16:58:51 UTC] RC5-72: Benchmark for core #6 (MH 1-pipe 604e)
    0.00:00:16.17 [5,171,342 keys/sec]
    [Sep 15 16:58:51 UTC] RC5-72 benchmark summary :
    [ Edited by Spectre660 15.09.2017 - 14:00 ]
  • »15.09.17 - 16:59
    Stream Quad G5
    Each test below will take on the order of 34862 microseconds.
    (= 34862 clock ticks)
    Copy: 2926.7 0.054736 0.054670 0.054815
    Scale: 2903.6 0.055172 0.055104 0.055203
    Add: 3359.6 0.071593 0.071437 0.071846
    Triad: 3377.3 0.071144 0.071063 0.071237
    just for compare Stream P5040
  • »15.09.17 - 17:22
    AyoS
    Posts: 410 from 2003/8/13
    I just bought a G4 Mac Mini for my son... he's decided after 7 years of living apart to partially inherit my Morphos Addiction. So just in time for Christmas I got him a 1.42ghz with 1gig... This thread gave me more then enough data. Thanks
  • »14.12.17 - 05:15
    Posts: 2053 from 2003/6/4
    Growing the MorphOS _family_...
  • »14.12.17 - 06:32
    Posts: 1246 from 2004/2/8
    If any other means of attracting new users fail... There's always reproduction ;)
  • »14.12.17 - 07:53
    Addendum:
    > does your source also give away what the actual cause of the problem is?
    > The SoC's memory controller? The board design? Anything else?
    Observation of low memory performance on boards with e6500-based CPUs:
    https://community.nxp.com/thread/467386
    2 years ago i was say exactly the same about e5500 P5020 and P5040. "low memory performance like a penium 4 first generation" but everyone from a-eon ignore me in beginning and joke me in the end ....
    really happy because i sold everything and close this bad experience.
    [ Edited by tlosmx 23.01.2018 - 14:19 ]
  • »23.01.18 - 14:15
    just for stay in topic this is what the G5 Quad do on debian ppc64 ;-) MOS PLease!
    video
  • »23.01.18 - 16:51
    video
    Even if there will be a version of MorphOS for Quad G5 (which is not likely) it won't be really so much better performing than currently supported top-of-the line G5 (except for the gfx speed of course). For example the Kraken Benchmark result was 108643.5 ms on G5 DP 2,7 GHz (MorphOS 3.9, OWB 1.24) vs 114303 ms on G5 QC 2,5 Ghz (MorphOS beta, OWB 1.24).
  • »23.01.18 - 17:14
    > Quad G5 [...] won't be really so much better performing than currently supported
    I think the main advantage of the Quad G5 (and other PowerMac11,2 systems) over currently supported G5 systems is clearly the ability to use rather modern, easily obtainable PCIe graphics cards (even non-Mac ones with some restrictions).
  • »23.01.18 - 19:14
    zukow
    Posts: 642 from 2005/2/9
    Yes and no, RadeonHDs don't work out of the box in PowerMac11,2. Proper init code needs to be written/fixed. So it's not the case: cards works in Sa,460, it will work in G5 PCIe.
    btw. I'll have current version of MorphOS on G5 PCIe with RadeonHD card during
    https://chal.pl/amiparty-xxii/general-information-english-version/
  • »23.01.18 - 20:23
    for what i test on linuxppc G5 quad works 4xxx,5xxx,6xxx and 7xxx series the important is have the boards on the 8x slot.
    @koszer
    about 970MP vs 970fx . we need to use mos for compare ... ;-)
    for now this is geekbench
    970fx
    64 http://browser.geekbench.com/geekbench2/161838
    32 http://browser.geekbench.com/geekbench2/192836
    970MP
    64 http://browser.geekbench.com/geekbench2/2635869
    32 http://browser.geekbench.com/geekbench2/2639804
    [ Edited by tlosmx 23.01.2018 - 23:53 ]
  • »23.01.18 - 23:52
    Yesterday i had been test the Asus R7 250 2GB ddr5 on Quad G5 and i can confirm it is work under linux in Fbdev mode ... because radeonSI is not working on linuxPPC because endianess.
  • »28.01.18 - 09:37
    GCN Gen1 compatibility doesn't surprise me.
    How about Gen2 like an R7 260X?
  • »28.01.18 - 15:30
