Posts: 2026 from 2003/2/24
Desktop-Dynamite wrote:
Now my current issue is with youtube struggling to play 360p or higher in both windowed and full screen mode, where I doubled checked OWB where I have the latest version 1.24, albeit the about website homepage shows v1.23 [ is that a mistake ?]
Hmm.. it tells 1.24 for me everywhere as far as I can see now...
As per title of this post I have also enabled the latest script.
You could also try to remove the fullscreen fix script completely first and add it again then. I think I once had old short list of "Allowed Sites" and newer script added more of them.
Am I limited according to the GPU specs ? [4x AGP and 32Mb]?
No, not for 360p at least.
Is there anyone with the same iBook G4 specs as mine that could shed some light and perhaps post a video link showing youtube videos playing smoothly?
I have the exactly same model, and well.. here's a quick video to prove that it can play YouTube videos with the built-in player (assuming you can view YT videos smoothly on some other machine) :)
https://youtu.be/O-BadE1lq5oQuote:
Is there any other tweak to do?
All I can advice is to double check these:
http://library.morph.zone/Tips_and_Tricks#Problems_with_YouTube_VideosAnd don't click the fullscreen button before the actual video plays! If you click it too early (when the round thing is spinning), it breaks the fullscreen fix and you have to reload the page.
Also what plugins must be enabled, and what is the correct setting of "spoof as" ?
No plugins should be enabled, and no YouTube converter scripts, just the fullscreen fix script. And don't spoof anything (use the default).
[ Edited by jPV 11.12.2017 - 18:48 ]
