Hexaco (a colour codes tool) needs tests
    r-tea
    Posts: 301 from 2005/3/27
    Guys,
    recent few months I've played with AmigaE compiler and MUI autodocs.
    I have made a tiny tool intended for easily choosing a colour and copying its code to system clipboard.
    There is an older version available on Aminet. Now I improved my program a bit.
    Hexaco 0.9.8
    icon
    It's AmigaOS 68k binary.
    The icon contains few supported tooltypes.
    Can you, guys, test it for me? Especially I need tests under AmigaOS 3.x.
    I miss draggable screens... and do you? I know I'm in a minority unfortunately.
  • »28.05.17 - 20:18
    NewSense
    Posts: 1475 from 2012/11/10
    I tried it on MorphOS, and it runs OK as a 68k executable without any issues that I came across, but it's not much use to me personally.
    I hope it is of some use to someone else though. ;-)
  • »31.05.17 - 01:27
    r-tea
    Tkank you. Do all icon tooltypes work correctly?
    Have you tested string gadgets for inproper input format?
  • »31.05.17 - 07:02
    r-tea
    Due to bugs in the last version I stepped back to one of previous sources and started to carefully add missing features step by step.
    Additionally I rearranged the GUI.
    Can you test the particular downgraded versions?
    To avoid mix-ups I described what parts don't work and what I succesively added.
    Dec/hex/bin String field doesn't work as input for now. HTML name String field as well.
    Both strings have no limitations as for range of input chars and number of chars.
    Hexaco_2017-06-10
    icon
    Added: HTML String field work as an input while selecting a name from the list as well as while typing in by hand.
    Hexaco_2017-06-10_1
    icon
    Added: hex/dec/bin String field now works as an input. Additional it has limitations of number of chars to input and of range of chars. Limitation change according to the cycle gadget state.
    Hexaco_2017-06-10_2
    icon
  • »10.06.17 - 20:04
    r-tea
    New, slightly chenged version. Fixed few bugs reported on other forums.
    I especially need tests on classic Amiga ECS/AGA OS3.x.
    Hexaco 2017-06-14_1
    icon
    [ Edited by r-tea 17.06.2017 - 11:36 ]
  • »17.06.17 - 10:35
