Get Gmail and YouTube to work by moving cookies.db to MorphO
    MorphDelf
    Posts: 274 from 2004/2/20
    Hi!
    I've made an article regarding getting Gmail and YouTube working again on MorphOS. Slowly OWB 1.24 and my Google accounts stopped to work. Seems like Google changed their cookies policy or something.
    Well!.. OWB 1.25 for AROS or AmigaOS 4 can solve this. You need to start OWB to get the cookies.db file in your Conf drawer though.
    Just copy cookies.db file to where you have your OWB for MorphOS. This also works with OWB 1.23 etc!
    Source
    Check the article on Amitopia website
  • »21.02.17 - 14:25
    vulture
    Posts: 189 from 2008/2/4
    Ummm.... so there's an owb 1.25 for OS4? I thought only AROS had that.
  • »23.02.17 - 11:28
    Posts: 12075 from 2003/5/22
    Yes, you are right. Most recent OS4 version (May 2016) is designated as v1.23r4. The reason some like to call it "v1.25" is probably this:
    "backported deadwood's fixes from 1.25:
    - fixed major memory leak where Frames were not released together with their JS data - memory no longer continuously consumed while browsing
    - fixed a number of small memory leaks
    - fix for cookies, which make login to youtube, blogger and some others works again.
  • »23.02.17 - 12:16
    vulture
    Oh, ok, makes *some* sense I guess.... thx!
  • »23.02.17 - 19:56
    defender
    Posts: 247 from 2011/4/24
    We rather need a cookie.db tool or a howto create cookie.db for OWB.
    Because I for example have no x86 or x64 machine to create such a file.
  • »25.02.17 - 09:24
    kriz
    Posts: 309 from 2005/10/18
    Damn MorphDelf don't steal others solutions and spread it as your solution.. But this needs a MOS tool or fix, most wanted .. Hopefully it leaves for a solution soon :)
  • »27.02.17 - 07:14
    Posts: 1246 from 2004/2/8
    Well, OS4 folks have a working solution. AROS folks have a working solution. MorphOS developers have a working solution. It's just us, users that have to wait. Or maybe there's a chance for a standalone OWB version, MOS-team?
  • »27.02.17 - 07:52
    Cego
    Posts: 712 from 2006/5/28
    anything new to solve this issue? i still cant login into YouTube and i dont have an AROS or OS4 machine.
  • »22.09.17 - 14:21
  • szt
    szt
    Posts: 53 from 2004/10/9
    If you have a backup of the cookies.db from that period when your google account worked, then just overwrite with that the existing one.
    MorphOS 3.9
    PowerMac 7,3, 1,8GHz,
    Radeon 9600
    300 GB SeagateHDD, 120 GB Samsung SSD
    LGM2382D, Canon MG7550
  • »22.09.17 - 19:52
