Does AmigaE survive an architecture change?
    asrael22
    Posts: 404 from 2014/6/11
    In case the new MorphOS runs on x86_64 or ARM would there be a native AmigaE/PortablE build?
    PortablE is still maintained, so chances are good?
    But standard AmigaE or ECX?
    Manfred
    [ Edited by asrael22 13.01.2017 - 20:33 ]
  • »13.01.17 - 17:21
    Posts: 779 from 2007/10/23
    unlikely
  • »14.01.17 - 11:51
    Posts: 2236 from 2003/2/24
    PortableE generates C source code which can be compiled pretty much everywhere from 6502 to MIPS so that should work atleast on the compiler level.
    How that generated code will cope with API changes and wether PortableE will be adapted to those is a different matter.
  • »14.01.17 - 12:06
    igracki
    Posts: 389 from 2003/2/25
    Well, ECX's source is public, so one (maybe Leif himself?) could add a new target!?
    I already fixed some smaller bugs myself (including a bug in the library generator).
    I didn't have the knowledge now to add a new target myself, but maybe in the future when MorphOS 4 (or 5) will be released.
    The longer it takes, the more time I have to eventually learn how to do it;)
  • »14.01.17 - 15:52
    asrael22
    For PortablE, Chris is maintaining this for more than 10 years. I believe he can add a new target as well (maybe with help of others).
    OK, I didn't know the sources for ECX were public domain.
    Manfred
  • »14.01.17 - 15:55
    Leif
    Posts: 111 from 2006/5/31
    Hi Thomas.
    I doubt I'll add the x86 target, myself anyway, due to lack of time and I rather work on a new lang/compiler if i would get the time.. :) Anyway anyone who would be willing to
    attempt this, can email me and I will try answer any questions. I have put up the source
    on bitbucket for now (https://bitbucket.org/sproing/ecx). But not sure if there are any suitable tools for version control on Amiga/MorphOS yet (uses GIT). This is not the absolutely latest yet (just a copy of the latest public archive) I will add some more
    fixes by me and others in coming days.
    /Leif
  • »14.01.17 - 21:45
    asrael22
    I would imagine making x86 target is not a trivial task. Lots of native things to be done, mabe even in Assembler.
    Manfred
  • »15.01.17 - 11:39
