Maddening User Interface
    ausPPC
    Posts: 543 from 2007/8/6
    It seems that I have to include a third row of label objects under 'VRSAVE' in order for the the columns to be centered...
    Source file on github.
    Any suggestions, hints etc are most welcome.
  • »11.01.17 - 21:30
    Tcheko
    Posts: 510 from 2003/2/25
    It isn't really clear about what you'd like to achieve.
    Also, as a side note, wouldn't it be nicer to use inverted text for bit state instead of wasting space with 0/1 (single_bits array) ?
    Inverted text label would means bit is high. Just an idea to streamline a bit the UI.
    [ Edited by Tcheko 11.01.2017 - 21:54 ]
  • »11.01.17 - 21:46
    ausPPC
    Thank you for the quick reply. I'm still just scratching the surface with MUI and I don't know what inverted text is - so please tell me more. Also, I agree about there being too many individual elements (and this is just one window out of several) but I don't know any alternative. So again, I'm open to suggestions.
  • »11.01.17 - 22:17
    Tcheko
    Inverted text is when the background is drawn with foreground color. that's JAM2 rastport mode afair.
    It is like when you select some text with the mouse. Foreground/background colors are inverted.
    There is an escape sequence for that. I think it is "\033B". Didn't checked.
    Also, you could experiment MUIA_Group_Spacing, 0 to save some window estate and pack label tighter.
  • »11.01.17 - 22:38
    ausPPC
    Admittedly, the difference in element alignment between those captured windows is minor but, now that I've noticed it, it's quite irritating...
    In the 'not centered' image, the zeros under 'VRSAVE' appear to be left aligned (yes, you have to look closely - they're only out by a pixel or two). That doesn't seem to be the case with the other groups - but those groups have other rows of elements following the zeros. So, in the 'centered' image, I added another row (without changing any other MUI attribute tags) which seems to have caused the desired alignment...
    Maybe I've stumbled upon a bug in MUI...
  • »12.01.17 - 21:55
    Posts: 2971 from 2003/3/5
    The single_bits objects are using MUIA_Width_FixWidthTxt - so basically you're telling the MUI engine that the object must not exceed the width of the "0" character while you want the columns containing those objects to fix larger objects too. The proper approach would be to use MUIA_HorizWeight with a low value (you've got to experiment there a bit) on all the objects in a column.
  • »13.01.17 - 01:01
