Problem with new sdk
    imax
    Posts: 41 from 2004/9/20
    Hi All !
    An older version (2003) of the compiler works ok.
    I do try compile of "nether earth remake" at new sdk-20160122 and sdk-20150619
    and i see :
    g++ -O3 -noixemul -c nether.cpp -o nether.o
    In file included from nether.cpp:15:
    list.h:68: `List' is not a template type
    list.h:68: redefinition of `struct List'
    /gg/os-include/exec/lists.h:24: previous definition here
    list.h:70: non-template type `List' used as a template
    list.h:70: ANSI C++ forbids declaration `' with no type
    list.h:70: abstract declarator `int ()()' used as declaration
    list.h:71: non-template type `List' used as a template
    list.h:71: confused by earlier errors, bailing out
    make: *** [nether.o] Error 1
    list.h :
    68 template <class T> class List {
    69 public:
    70 List<T>() {list=0;act=0;top=0;original=true;};
    71 ~List<T>() {
    72 if (original) {
    73 delete list;
    74 } /* if */
    75 };
    76 List<T>(List<T> &l) {list=l.list;act=list;top=l.top;original=false;};
  • »03.02.16 - 20:29
    CISC
    Posts: 619 from 2005/8/27
    imax wrote:
    Hi All !
    and i see :
    This is an include issue, and probably not a compiler issue, so I suppose you mean older version of the SDK...
    I'm guessing the problem is that some include (GL/SDL/?) is now including exec/lists.h containing struct List which directly conflicts with the List class in list.h.
    The easiest fix is probably to redefine List in list.h.
    - CISC
  • »04.02.16 - 07:47
    imax
    Hi CISC !
    I tried different versions that I had and here's the result:
    SDK2.7 (20110916) - compile OK
    SDK3.2 (20130129) - compile OK
    SDK3.5 (20140508) & newer - compile error
    i did replace the list.h of any version - the result is the same (the same files).
    I had a break in programming at age 6, please tell me how "to redefine List in list.h."
  • »27.02.16 - 20:32
    BSzili
    Posts: 559 from 2012/6/8
    You have two choices: either rename your list class to something else (e.g. MyList) or let the preprocessor do it for you, by adding this line to the beginnig of your list.h:
    #define List MyList
    If you choose the latter, make sure to include your list.h after the system headers, or you'll end up redefining List in the system headers too.
  • »27.02.16 - 20:54
