MorphZone has moved
  • ASiegel
    Posts: 1387 from 2003/2/15
    Hello, this is just a quick note to say that MorphZone has moved. If anybody continues to experience performance or connectivity issues on a regular basis, please let us know. Thank you.
  • »10.02.16 - 17:58
    I can not click on user IDs to bring up their user info.
    It acts like it is looking to the old server.
  • »10.02.16 - 18:08
    emeck
    Posts: 175 from 2014/7/15
    @ASiegel
    News are not accesible:
    Not Found
    The requested URL /modules/news/article_storyid_2268.html was not found on this server.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »10.02.16 - 18:33
    Posts: 12408 from 2003/5/22
    Yes, the https://morph.zone/userinfo.php?uid=xxx URL scheme works while the https://morph.zone/users/xxx.html one does not.
  • »10.02.16 - 18:38
  • ASiegel
    Thanks. Just a minor configuration issue. This should work now.
  • »10.02.16 - 18:49
    Posts: 2726 from 2003/2/24
    Great move! ;-)
  • »10.02.16 - 18:53
    pampers
    Posts: 1061 from 2009/2/26
    Yay finally!
    MorphOS 3.x
  • »11.02.16 - 07:47
    Posts: 1932 from 2003/10/19
    Im not able to connect on any of my MorphOS machines without getting an Error 60: CA certificate not fond error now.
  • »14.02.16 - 21:12
    TheMagicM
    Posts: 1220 from 2003/6/17
    disable ssl errors
  • »15.02.16 - 01:48
    beworld
    Posts: 664 from 2010/2/10
    hi all,
    Just a confimation : it's possible to update curl-ca-bundle.crt in OWB folder ?
    https://curl.haxx.se/ca/cacert.pem
    BeWorld
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »15.02.16 - 08:40
    Posts: 2165 from 2003/2/24
    Hmm.. what version of OWB are you using? I haven't got any errors when tried with couple versions...
    Anyway great that the site is more responsive now!
    [ Edited by jPV 15.02.2016 - 17:56 ]
  • »15.02.16 - 13:55
  • ASiegel
    The website is still using the exact same SSL certificate that it has used for about a year now. It is not obvious to me how the server move could cause the issue that you are describing.
  • »15.02.16 - 14:15
