How to capture shell command output
    asrael22
    Posts: 404 from 2014/6/11
    Hi.
    Is is possible in Arexx to capture the shell output of a command?
    Assume this command:
    ADDRESS COMMAND "list sys:"
    Can the output of this be captured into a variable?
    Manfred
  • »26.01.16 - 18:21
    defender
    Posts: 236 from 2011/4/24
    Maybe this helps you:
    list sys: >Ram:list.txt
    only if I understod what you want.
    you list of sys is recorded as list.txt in Ram:
    But its more amiga dos then arexx I think.
    CD32 - PowerBook 1,67GHz 1GB/100GB - MorphOS 3 reg. 1455
  • »26.01.16 - 19:46
    asrael22
    Well, it probably works.
    I could read the file in Arexx after the command execution comes back.
    It's a bit a detour but nevertheless.
    Manfred
  • »26.01.16 - 20:27
  • fx
    fx
    Posts: 25 from 2010/10/12
    I think you could use pipe: to not have to write to a file
  • »26.01.16 - 21:04
