Video Toaster someone?
    Posts: 2065 from 2003/6/4
  • »01.03.04 - 09:39
    I just saw that this topic is covered already. Next time I will have a better look before posting...
    Anyway, would be cool if someone jumps on that train...
  • »01.03.04 - 10:13
  • jah
    jah
    Posts: 69 from 2003/3/24
    i dont think you can plug this thing into a pegasos
  • »01.03.04 - 10:51
    discreetfx
    Posts: 399 from 2003/7/26
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »01.03.04 - 10:54
  • jah
    jah
    68k asm will take loooong time to port
    at end you will have a software designed for 64colors max
    that was for the user-interface part.
    pci toaster dont differ heavily ? i fear they have little in common
    with amiga toasters :(
    perhaps it would be easier to directly get the tech doc/specs of
    mordern toasters ...
  • »01.03.04 - 12:35
    Posts: 2451 from 2003/2/24
  • »01.03.04 - 14:21
