Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
MorphZone
Website
Login fails
Posts: 2021 from 2003/2/24
If you try to log in with login block on left side, it seems to fail now. Login from the error page it gives works though.
jPV's MorphOS pages
24.10.14
08:18
pampers
# 2
Posts: 1061 from 2009/2/26
Thanks for the tip.
MorphOS 3.x
24.10.14
08:45
Posts: 2720 from 2003/2/24
Same here...
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
24.10.14
11:29
Yasu
# 4
Posts: 1724 from 2012/3/22
Me too.
AMIGA FORUM
- Hela Sveriges Amigatidning!
AMIGA FORUM
- Sweden's Amiga Magazine!
My MorphOS blog
24.10.14
11:44
ASiegel
# 5
Posts: 1369 from 2003/2/15
Thanks for the reports. It is being investigated.
24.10.14
11:45
ASiegel
# 6
This issue should be solved. Apologies for any inconveniences caused.
24.10.14
11:56
