Pagestream 4.0.8 again
    WeiXing3D
    Posts: 327 from 2012/6/13
    I just reconfigured a "new" Mac Mini G4 1.5GHz, 1 GB RAM with MOS 3.4
    I moved or copied my old installation of Pagestream 4.0.8 from a backup that I made from my old Mac Mini. PS launches and opens fine using the Pagestream Assign icon, but it doesn't open when clicking on the Pagestream default app icon.
    Of course, as this was a direct copy of my old installation my user-startup doesn't contain the PS script. Can I add the script manually to the user-startup? If so, what should be the script?
    Thanks in advance for any advice.
  • »03.02.14 - 04:45
    Posts: 12501 from 2003/5/22
    > when clicking on the Pagestream default app icon. Of course, as this was a direct
    I guess the answer might be contained in one of those threads of yours:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9585&forum=16
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9592&forum=9
  • »03.02.14 - 06:08
    Posts: 1370 from 2010/1/6
    Please check also Ambient filetype (path) for PS!
    -> AmbientPrefs/Filetypes/Applications/x-Pagestream -> click on item "Open with". There should be the correct path to Pagestream.
    e.g. <Your full path>/PageStream4 %sp .
    Type has to be "Workbench" and Action should be "Double click".
  • »03.02.14 - 10:15
    WeiXing3D
    Thank you Amigaharry2, but I don't have a x-Pagestream icon under AmbientPrefs/Filetypes/Applications/.
    Do I have to create one? How?
  • »03.02.14 - 15:55
    First:
    Create a text-file with following content, name it x-pagestream and copy it to System:Prefs/Ambient/filetypes/application/
    AMTD
    1
    Type application/x-pagestream
    Name PageStream Document
    Action
    Name Open with
    Event DoubleClick
    Command WORKBENCH Work:PageStream4/PageStream4 %sp
    Flag cd source
    End
    End
    Don't forget to change to your path for Pagestream-location!
    Second:
    If default Pagestream-icon does not exist in your DefIcon-drawer, then create one (you can take one from some icon-sets on Aminet or from elsewhere).
    In my case it's located here: System:Prefs/Presets/Deficons/application/x-pagestream.info
    Maybe it's located on another place at your system - you can check the actual path in AmbientPrefs/Miscellaneous/ -> path to DefIcons
    Third: reboot
    [ Editiert durch Amigaharry2 03.02.2014 - 19:34 ]
  • »03.02.14 - 17:33
    WeiXing3D
    @Amigaharry2
    I forgot to give you thanks for your reply and advice. It worked perfectly.
    On a related or similar issue, I came across my old and orginal installation of Pagestream 3.2 yesterday and I decided to also give it a try, since it worked very well with my previous Mac Mini G4 1.2Ghz.
    It's working but it messed up my user-startup and now everytime I logon is asking me to assign volume Work:Pagestream32.
    This is how my user-startup file looks like now, and IMPORTANT - THIS IS ALL THAT MY USER-STARTUP SHOWS NOW, nothing more:
    ;BEGIN PageStream3
    Assign PageStream3: "Work:PageStream3"
    Assign SoftLogik: "PageStream3:SoftLogik"
    Assign Fonts: "PageStream3:SoftLogik/Fonts" ADD
    ;END PageStream3
    ;BEGIN ARexx
    sys:system/rexxmast >NIL:
    ;END ARexx
    How to edit my user-startup so that it boots up straight to Ambient?
  • »10.02.14 - 16:01
    Try this:
    Additional insert following line after ;BEGINN...
    assign Pagestream: Work:Pagestream3
    AFAIK older Pagestram-versions needs a assign to keyword "Pagestream" (without any number) too...
    With this assigns Pagestream 3.3 is running properly on my A3000......
  • »10.02.14 - 16:37
