MUIA_Text_Copy
    r-tea
    Posts: 300 from 2005/3/27
    Does anyone know what does this attribute do?
    MUIA_Text_Copy
    There is no info in autodocs.
    I thought it makes text markable and able to copy it into clipboard, but it not.
    I miss draggable screens... and do you? I know I'm in a minority unfortunately.
  • »30.12.13 - 00:01
    naTmeg
    Posts: 135 from 2004/2/8
    Form the SDK:
    NAME
    MUIA_Text_Copy -- (V20) [ISG], BOOL, 0x80427727
    FUNCTION
    When set to FALSE, the contents will not be copied to a
    private buffer. Defaults to TRUE, unless MUIA_Text_HiChar
    is also specified.
    SEE ALSO
    MUIA_Text_Contents, MUIA_Text_HiChar
  • »30.12.13 - 00:09
    r-tea
    Thank You..
    So,there is not about copying to clipboard.
    Have to switch to up to date MUI's documentation :-)
    BTW, how to make simple text object content markable and copyable? But in different way than using string object.
    [ Edited by r-tea 02.01.2014 - 23:16 ]
  • »02.01.14 - 23:03
    Tcheko
    Posts: 510 from 2003/2/25
    Subclassing?
  • »03.01.14 - 00:08
    Posts: 2971 from 2003/3/5
    r-tea wrote:
    Thank You..
    There's an extra tag to enable this - just see that the MD5 string in Ambient info is markable again. Please wait for the next SDK...
  • »03.01.14 - 07:42
    r-tea
    Is there mode yet undocumented MUI's attributes/methods like the one you have mentioned?
  • »03.01.14 - 15:25
    You mean private ones? About as many as documented ones :)
  • »03.01.14 - 16:40
    r-tea
    No, I mean ones pretend to be public. One day... :-)
  • »03.01.14 - 21:24
    r-tea
    Probably this is in MorphOS 3.4, because the MD5 Info's string in my MOS 3.3 is unmarkable.
  • »04.01.14 - 20:22
    And why would you use 3.3? It was indeed something I've added to 3.4.
  • »05.01.14 - 13:15
