What to do with efika?
    JohnFante
    Posts: 156 from 2006/9/4
    That would be really great :-)
  • »29.07.08 - 09:24
  • Targhan
    Posts: 2833 from 2003/2/8
    Ze first picture of what to do with an Efika if you are Targhan..
    What I would like to do soon, is to create a wireless to wired network box. wirelessG->Efika->Ethernet But... that is a story for a different post.
    Note: Neon Genesis Evangelion Mousepad .. LOL
     Attached file(s)
    :idea:Targhan
  • »29.07.08 - 20:42
  • Targhan
    Details:
    case is a cosmetics case.
    PSU installed upside-down, to *prevent* airflow (yes, on purpose, and I have not shared this part of the info before. I did it wrong on purpose to MAKE it run HOT.)
    GFX: Recovered card from an early ODW that was deader than a doornail.
    HDD from somewhere, I honestly can't remember what scrap pile I pulled it from. (new my tail).
    Sadly, I was not able to get the mini-LCD screen w/speakers to work at all. it was burnt out. would have been kewl to have the monitor glued to the side of the little box.....
    :idea:Targhan
  • »29.07.08 - 20:47
    ausPPC
    Posts: 543 from 2007/8/6
    I'll be adding to my blog later today.
    Yes, the LED is blue!
    [ Edited by ausPPC on 2008/7/31 9:58 ]
  • »31.07.08 - 00:56
    ausPPC
    Quite a few fresh pics over here.
  • »31.07.08 - 07:41
    xyphoid
    Posts: 870 from 2008/7/11
    using cli works best, mame 030-060,97 110 works sweet even using defaults.
    update to the ones i tried
    punchout
    mr. do
    gunsmoke
    ms pacman
    pacman
    sly spy
    final fight- seems abit slow
    chase hq- 75% speed
    streetfighter II-76% feels like 030
    So speed isn't 100% on a few still very playable!
    one issue joypad emulation one 2player games. usb pad moves both players
    simultaneously. guess i'll start a new thread on this!
    We need that sound driver badly!!
    anyone got that old amp2 to work?(amidog's)
  • »01.08.08 - 05:45
    xyphoid
    looking for something else to do. How do you get virtual GP2 on efika?
    there's this link
    http://www.pegasosforum.de/dload.php?action=file&file_id=664&sid=fd5d183c85e0d87b3a7555d55891c572
    and http://www.siniscope.com/vgphd/home.html
    for the latest updates.
    then what?
    glquake couldn't find gfx.wad, but i put pak0-pak3 files in. Do i need something else? what's the deal with quake 3?
  • »07.08.08 - 01:41
    ausPPC
    Just finished this case -
    You can see a larger version of it and my other systems on my blog by clicking on them.
  • »22.09.08 - 08:34
