Change the font color on a Window --> List view.
    CountRaven
    Posts: 566 from 2007/12/11
    Hello folks!
    Is it possible to change the font color on a window list view?
    I have installed Chrysalis, selected a skin but I have added a pic of my prefernce on the Window background. When a Window is switched into ico view the letters are displayed on a white color, everythiing ok. However I need to change the black font color on the Windows list view.
    Is it possible?
  • »08.07.13 - 13:18
    Jambalah
    Posts: 820 from 2008/3/30
    Hello CountRaven!
    You can change the colors of a window when switched in list mode inside Ambient Settings/Lists. There you have all colours settings of dirs, files, selected files, and so on.
    [ Edited by Jambalah 08.07.2013 - 15:13 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.07.13 - 14:11
