Roadshow 68K on MorphOS 3.1 (it works!)
    Nadir
    Posts: 157 from 2003/3/17
    Just a small teaser: I spent some time in December to update the MorphOS NetStack (using a newer FreeBSD code base). We hope to ship this with MorphOS 3.2 already since it seems work really well.
    I don't have any benchmarks, but it is fair to say that it significantly faster than the old stack in many cases.
    Nicholai
    [ Edited by Nadir 03.01.2013 - 18:10 ]
  • »03.01.13 - 17:48
    Posts: 1033 from 2004/9/23
    I am using the Pegasos2 as my main system and never felt that network is slow.
    Maybe it is the kind of usage, maybe the SSD is compensating the speed issues. Who knows.
    Anyway installing some foreign stack may causing incompatibly with other system components, especially after updating the system in the future. Just be warned, that you are on your own.
    Geit
    PS. Since Nadir already spoiled the updated NetStack, It may be wise to not get something you may not need in the future.
    [ Edited by geit 03.01.2013 - 18:51 ]
  • »03.01.13 - 17:48
    redrumloa
    Posts: 1424 from 2003/4/13
    Nadir,
    Nicholai
    Hot damn! :-o :-o :-o
  • »03.01.13 - 18:44
    Dragster
    Posts: 98 from 2005/11/6
    Nadir,
    Nicholai
    Thank you! That's very good news, it's about time!
    Cheers,
    Dragster
  • »03.01.13 - 18:48
    hooligan
    Posts: 1948 from 2003/2/23
    Since it does not work on MorphOS (yet) I did not accept the newsitem, in case someone is wondering why it isn't posted here as news.
  • »03.01.13 - 18:56
    Jambalah
    Posts: 820 from 2008/3/30
    Nadir, thanks for let us know this interesting preview :-)
    @Hooligan:
    that's a reasonable point of view. We'll just whisper it around... ;-)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »03.01.13 - 19:07
    Posts: 12085 from 2003/5/22
    With news items on all major Amiga sites there's no need to whisper I guess ;-)
  • »03.01.13 - 19:58
    boot_wb
    Posts: 874 from 2007/4/9
    Good news, 3.2 is looking to be a big release.
    Although personally I find connection speeds per se are fine (html5 speedtest results) I do find I have problems with some sites (and within my LAN).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »04.01.13 - 01:50
    boot_wb
    @Dragster
    I'd be interested to know your results. I did give it a quick try on my Powerbook, but couldn't get it working.
    From what I thought I understood of the readme, the PPPOE driver supplied is just a wrapper - whether that's compatible with our sungem drivers or not I remain unsure.
    (PS - I disabled netstack by renaming mossys:net/netstack and rebooting)
    EDIT: Forgot to mention that the install script fails with MorphOS installer, but works with 68K installer.
    [ Edited by boot_wb 04.01.2013 - 17:09 ]
  • »04.01.13 - 01:56
    Dragster
    Well, unfortunately I haven't been successful making it work... it just doesn't...I've tried with bot of my pegasos II nics settinig up dhcp config and static ip/routing/dns... nothing.. in DHCP it can't negotiate the IP address... in static ip address config it appears to work but it doesn't really work.. you can't even ping anything, not even the gateway... the documentation states: "Operating systems which are highly compatible with these original Amiga operating system versions, such as MorphOS, are also expected to work with Roadshow."... since MOS is not oficially supported or anything I guess it would not make sense to confirm the author that eventhough it's expected to work in mos, actually it doesn't.
    Cheers,
    Dragster
    EDIT: It's worth to mention that I tested it on my A1200 with a pcmcia wifi card and it worked in dhcp setup with the same adsl modem/router right out of the box...
    [ Edited by Dragster 04.01.2013 - 10:54 ]
  • »04.01.13 - 16:51
    Dragster
    A little update on this... I finally was able to get roadshow to work under MorphOS 3.1... it's blazing fast!
    I used an USB ethernet card that gets binded to the usbasixeth.device woth Poseidon...configured it and voila, it worked! So it seems the devices for the Pegasos II ethernet port are not compatible with Roadshow for some reason...so if you want very fast ethernet, get roadshow and a USB network card for your MorphOS machine...
    Cheers,
    Dragster
    [ Edited by Dragster 08.01.2013 - 10:57 ]
  • »08.01.13 - 03:58
    Dragster
    OK...figured it out now ... got it working with my Pegasos II ethernet (via_rhine) *and* on my Powerbook!
    Here's the catch:
    The sungem_eth.device on the PB and the via_rhine_pci,device on the Pegasos II cannot be "initialized" by roadshow for some reason... so what I had to do on the powerbook to get it working was this:
    open a cli and type:
    online sungem_eth.device unit 0
    and then double click your roadshow configi/init file in devs:netinterfaces... and voila!
    I did the same thing on the Pegasos II with the via_rhinepci.device...
    So, roadshow *68K DOES* work (and it's very fast) under MorphOS 3.1!! YAY!
    Cheers,
    Dragster
    [ Edited by Dragster 08.01.2013 - 11:32 ]
  • »08.01.13 - 06:06
    catohagen
    Posts: 297 from 2003/5/20
    fuck finally :) thanx for this....olsen gets my cash today i guess :)
  • »08.01.13 - 06:44
    catohagen
    Maybe someone can submit/allow this as news now, as its :
    *works on MorphOS 3.1
    *works on Pegasos internal ethernet (via_rhine) on Morphos
    *works on Powerbook internal ethernet (sungem) on Morphos
    *most likely works on MacMini internal ethernet (sungem) on Morphos
    *works on USB to ethernet devices on Morphos 3.1
    *reported as 'blazingly fast' :) even as emulated 68k code :-o
    *Sales promotes hard working amiga coders still around
    *Morphos users with low throughput network transfers finally can stream/copy/backup their stuff(pron) with normal speeds around their home network instead of the low performance netstack people have reported with Morphos :-x
    [ Edited by catohagen 08.01.2013 - 08:24 ]
  • »08.01.13 - 07:22
    Wasn't the low NetStack performance reported for WAN, not for LAN? Fab reports a NetStack LAN speed of up to 10 MByte/s. Is Roadshow significantly faster than this?
  • »08.01.13 - 10:21
    catohagen
    I guess that depends much on the network of the individual who does the reporting but most of the reports i've seen from users is general low performance of network speed (and several replying morphos devs reporting top-notch network speed on their machines)
    In my case, on my 2 Macmini's and powerbook, my lan speed is average around 4-5 megabyte per second with morphos netstack.
    OWB downloads jumps to 50kb/s to 3-400 kb/s
    I can play with a cli and my nas mounted with smbfs and try
    'copy nas:ubuntu10_04.iso buffer 1000000 ram:' and get 5-6-7 megabyte/s or
    'copy nas:ubuntu10_04.iso buffer 10000000 ram:' and get 6-7-8-9 megabyte/s
    When copying from the Morphos side to nas, its around 2 megabyte/s
    my internet is 60 megabit up and down(fibre) or around 7 megabyte per second and browsing the web with OWB is usally slow, i did what Fab suggested somewhere to set tcp.sendspace and tcp.recvspace to 60000 for speeding up browsing, but then LAN filetransfers where really crap and halting so i had to revert to 8192 for tcp.sendspace and tcp.recvspace
    I'll get this Roadshow 68K stack running for a few days and test if network speeds on WAN and LAN get any better.
  • »08.01.13 - 11:55
    catohagen
    olsen wrote a reply to the way Dragster got the stack working on morphos
    http://www.amiga.org/forums/showpost.php?p=721764&postcount=21
    maybe some morphos dev with network knowledge want to read as it seems
    that network devices written for morphos doesnt behave correctly as Olsen
    points out in detail in the reply on amiga.org
  • »08.01.13 - 12:43
    redrumloa
    @Dragster
    The installer didn't do nasty things to your mossys:devs/networks?
  • »08.01.13 - 13:40
    hooligan
    Installer didnt do anything for me.. all I see is a quick flash of the install window before it disappears. I tried the latest demo.
  • »08.01.13 - 13:53
    Dragster
    redrumloa,
    Hey Red,
    nope... it doesn't copy anything to MOSSYS as far as I remember... anyway, it's very easy to install manually... so you can have total control over the installation...
    Cheers,
    Dragster
  • »08.01.13 - 14:37
    Dragster
    hooligan,
    Use the 68k installer... it works with that.
  • »08.01.13 - 14:37
    Piru
    Posts: 576 from 2003/2/24
    catohagen,
    Here's my email to Olaf Barthel:
    Hello,
    "I would hope that, unless there are specific reasons why
    sungem_eth.device and via_rhinepci.device do not open in "online" mode,
    these drivers will be updated to conform to the standard practice."
    There is no clear specification whether driver should be online by default
    or not. As such I will not change this behaviour. The correct solution is
    for the TCP/IP stack (or whatever software using the SANA2 driver) to
    explicitly S2_ONLINE the driver after S2_CONFIGURE has been done. Doing so
    has no ill effects as if the device is online already it will just ignore
    the command.
    The reason applications using SANA2 should go online explicitly can be
    tracked to ppp.device which does not go online automatically. In fact, for
    example with AmiTCP/IP you were supposed to add manual bin/online call to
    cover this. Example: http://www.amitrix.com/faqs.html
    Later AmiTCP/IP authors decided to move away from startnet script as such,
    and rather automate and consolidate this functionality to avoid the
    cumbersome startnet script generation that was quite inflexible and hard
    to maintain in an automated way (see AmiTCP installer script for some
    horror hacking).
    "netconfig" command was added. It could do for example BOOTP
    autoconfiguration. This command also covers the online-problem by always
    taking the device online, unless if explicitly told not to do so by a
    command line switch:
    NOONLINE/S - Do not put the Sana2 device online.
    Normally netconfig puts the Sana2
    device configured for interface-name
    online. This option causes the online
    command not to be sent.
    Miami/MiamiDX also puts the SANA2 device online automatically.
    As such I'd say it wouldn't be totally uncalled for for the TCP/IP stack
    to automagically S2_ONLINE the driver, nor should it be considered a
    problem in a device driver if it does not go online by default.
    Best Regards,
  • »08.01.13 - 18:53
    Posts: 2720 from 2003/2/24
    @Piru
    I think that was a good response.
  • »09.01.13 - 00:10
    hooligan
    Devs:netinterfaces is empty drawer for me, nothing to doubleclick. On top of that Roadshows uninstall broke the MorphOS bootsequence, had to boot from cd and manually remove roadshow related stuff from s:user-startup. This definetely won't go as news as it is :)
  • »09.01.13 - 05:34
